After two years the gas is going to be a little stale, depending on how much you've got in the tank and how skilled you may be at removing it, I'd lube the cylinders and try to fire it up. It will run on old gas, not well and with no power, but it may be easier to run it through than drain it out. Your call. Papa 70
