Author Topic: How important are the muffler heat shields?  (Read 1182 times)
Offline Challenger73318
« on: April 06, 2007 - 05:31:56 PM »
Subject says it all.  Why do I ask?  I was test fitting my Summit 3" exhaust kit tonight, and found that my car is missing the driver's side heat shield.  It has the passenger piece intact.  I was thinking that I could put Dynamat or similar in the trunk to make up for this shortcoming.  Any opinions on if this would work, even short term until I can find a decent replacement shield?
Re: How important are the muffler heat shields?
« Reply #1 on: April 06, 2007 - 06:38:37 PM »
the heat sheild keeps heat both out of the trunk & the gas tank as well , it would be ebtter to from a piece of steel to do the same thing
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #2 on: April 07, 2007 - 09:43:32 AM »
a 318 car only had single exhaust thus only 1 heat shield.
« Reply #3 on: April 07, 2007 - 04:55:15 PM »
That explains it...318 from the factory.  Somewhere along the line, flowmaster duals were put on.  Now I got it.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #4 on: April 08, 2007 - 05:00:28 AM »
the factory exhaust used mufflers and resonators in the rear which are larger in dia and therefore closer to the floor/gas tank.If you run aftermarket exhaust with the mufflers under the rear floor you can eliminate the rear shields.Flowmaster recommneds heat shields over the mufflers but I don`t run any and no problems!  :2thumbs:
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
« Reply #5 on: April 08, 2007 - 04:39:45 PM »
http://web.mac.com/khansen6/iWeb/Site/Exhaust.html
So the pipes are on.  Still not sure of the heat shield, but I think I'll look into some, err-ing on the side of caution.  Jegs has some that might work for $32 each.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #6 on: April 08, 2007 - 04:42:24 PM »
How does the Summit system fit?  I've been looking at the 2.5" system for my car.
Tom
Any pictures? :picture:
Tom
