Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
rear end problems advice needed
« previous
next »
Print
Pages: [
1
Author
Topic: rear end problems advice needed (Read 709 times)
72hemi
Resident
MEMBER SINCE JANUARY 2006
on:
April 06, 2007 - 06:08:35 PM »
I installed a new 3rd member into my 8 3/4 (3.91 posi out of a mid 60's D100) and when I went to slide in the axles, neither side would go in. I have no clue why the axles won't go in unless the splines are different. Does anyone have any ideas?
Logged
1996 Dodge Viper GTS Coupe
Chryco Psycho
Administrator
C-C.com Guru
Re: rear end problems advice needed
Reply #1 on:
April 06, 2007 - 06:40:20 PM »
typically the spider gears & axles gears may not line up if the sure grip has been disassembled so you may need to pry the axle with a crowbar between the whhel studs until the splines line up
Logged
72hemi
Resident
Reply #2 on:
April 06, 2007 - 06:50:24 PM »
That did the trick. Thanks.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
April 06, 2007 - 06:55:07 PM »
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
