I am looking at buying a 426 Hemi for the 71 'Cuda (when I find it). I would go for the 528 or 472 but the 528 especially, is too much engine IMO for a street driven "daily driver". Also, for me, when people talk Hemi, nothing screams Mopar than those famous three digits - "426". I have already decided that instead of buying a Mopar block over the counter, getting it here, tearing it down, blue printing, checking and reassembling, I will get it built by Ray Barton. I have not heard a bad word about him and many seem to speak highly of him and his engines.
I have a few questions that will not only help me but also offer some others help if they decided to do the conversion. At current, the 'Cuda is/was going to be a 340ci. What parts will I need to put a Hemi in? Do the k-frames come in big and small block variety or is there also a "special" Hemi k-frame? I know I may/will need new engine mounts, I've been told Arruzza's are the way to go as Schumaker mounts have too many problems. I also know that I'll have to install a small booster and offset linkage as I have power brakes (where would I get that from?). I will run tti headers, unsure of size at the moment. Any other items or parts needed to install a 426 into a 71 Cuda? I've informed Keisler of the swap so they have made the corrections to the 5-Speed set up, so, transmission mounts and hook-up is all sorted.
Another question, what kind of block is best? Aluminium, cast iron or graphite? I would like light so I'm thinking aluminium but is there any draw back with going aluminum? I just want the best, light, good power/flow and long lasting set up. I will be running a single 4bbl carb, Mopar recommend 750cfm Holley but I may go for a 850cfm Holley or Demon. I like the look of a 2 x 4bbl set up but under a shaker hood no one will see much and a 4bbl is a much easier setup to drive and live with on a daily basis, not too mention correctly tuned is right up there with any set up.
This is Ray Barton specs for their 426 Hemi builds:
- Mopar Performance Hemi Block
- Mopar or Stage V aluminum heads (what would you choose?)
- 4340 non-twist steel crank
- 4340 steel H-bean rods
- JE, CP or Diamond pistons (what would you choose?)
- RBRE rocker system
- Moroso oil pan
- Mopar or RBRE intake manifold (what would you choose?)
- EFI or carburetors available
- Professionally assembled
- Dyno testing available
Any input and help is much appreciated.
Cheers,
Carl
NZ440R/T
