Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Thermostat Housing Help Needed
« previous
next »
Print
Pages: [
1
2
Author
Topic: Thermostat Housing Help Needed (Read 7219 times)
MJS73
Sr. Member
on:
April 07, 2007 - 05:52:06 PM »
I need some help with a thermostat housing/leak problem. When I installed a new Edelbrock Performer RPM intake, I noticed that the thermostat housing was deteriorating, so I got new chrome one from Summit. It was then that I noticed that the new intake did not have a recess for the thermostat like the old intake did, but the thermostat housing did. So everything went back together, but I get seeping of coolant at the thermostat housing, even after tightening the clamp way down. I was told that the chrome thermostat housings don't seal as well as the OEM ones? So do I look for an OE thermostat housing?
Logged
www.mikes73.com
Don't PM me - send me an e-mail at
mjsavage2001@yahoo.com
GoodysGotaCuda
Sr. Resident
Re: Thermostat Housing Help Needed
Reply #1 on:
April 07, 2007 - 06:15:48 PM »
Chrome t-stat housings, SUCK. They usually at the very lease need to be flattened out, and have the tendacy to warp. (yes, there are a few that are fine, but the majority are no good). My local auto parts place had a stocker housing in stock. Sealed perfect on the first try.
Logged
Build Page:
Goody's 'Cuda Build Page
1976 Dodge Warlock
Wheel & Tire Specs:
Link
MJS73
Sr. Member
Reply #2 on:
April 07, 2007 - 06:20:35 PM »
Thanks, Mike. That's what I was hoping to hear.
Logged
www.mikes73.com
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
April 08, 2007 - 12:19:47 AM »
That has been my experience also virtually all aftermarket Housings will leak , often the groove for the T sta is cut otu too far & into the bolt holes & will never seal up
Logged
cudabuyer
Sr. Member
Reply #4 on:
April 08, 2007 - 05:50:18 AM »
exactly, get a stocker or leak like the Titanic & the Sea Diamond, unbelievable in this Day with loss of life
Logged
70 Dodge Challenger Convertible 6.1 Hemi
Topcat
C-C.com Expert
Member since 9/16/04
Reply #5 on:
April 08, 2007 - 08:19:04 AM »
I have seen a T stat housing that has an O ring seal built into it. I know they make it for Chebbies and Ferds but I don't recall who makes them. Mopar too?
I recall my woes in the past with Chrome T stat housings also and won't travel that path again. I would pay 20 for an OEM than 10 for a Chrome.
Logged
GoodysGotaCuda
Sr. Resident
Reply #6 on:
April 08, 2007 - 09:21:17 AM »
I hear the billet alum ones aren't having sealing issues, but are
Logged
Build Page:
1976 Dodge Warlock
Wheel & Tire Specs:
Link
MJS73
Sr. Member
Reply #7 on:
April 08, 2007 - 08:13:03 PM »
Mike, Did you use a gasket sealant on the water outlet, or just the gasket?
Logged
www.mikes73.com
Stacked440
Sr. Member
Reply #8 on:
April 08, 2007 - 09:41:01 PM »
I use spray-tack I believe its called, red colored gasket sealer in a spray can, you'll know its the right stuff if it has a sweet smell to it when you spray it.
I sprayed it on both sides of the gasket and on both the water pump housing and the thermostat housing, no leaks, cant complain
Logged
-Kyle-
IMNCARN82
Resident
LeDZeP
Reply #9 on:
April 09, 2007 - 06:29:56 AM »
Got 1 from Summit too..I tried formagasket. but I ended up taking it off and throwing it as far as I could
Logged
'73 340 5 speed,RMS,BAER,... "Supercuda" (O[ ]||||[ ]O)
'69 Dodge Charger 383,Auto (OiiiiiiiiiiIiiiiiiiiiiO)
13' Challenger R/T BlacktoP 6spd. (OO________OO)
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert "cuda bob"
KellysCuda aircard
Its good to be blown
Full Member
Reply #10 on:
April 09, 2007 - 06:46:41 AM »
Mine leaked also...and now sits on the shelf.
Logged
moparman11
Jr. Member
Reply #11 on:
April 09, 2007 - 07:43:58 AM »
I bought one with the o-ring, and used a sealant, still had a leak. someone told me it was the chrome plateing, they removed the plateing from the bottom, and it worked. I havnt tried it, but I think I will, John
Logged
1973 RALLYE CHALLENGER
EVIL72
Sr. Member
Reply #12 on:
April 09, 2007 - 07:48:14 AM »
Yep my chrome one leaked too, so I just repainted the stock one and now no problem.
I took a belt sander to one in high school until all the chrome was off the bottom and it didn't leak, but I've seen others do the same thing and it still leaked, so I must have just got lucky on that one.
Logged
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
pink panther
Resident
Reply #13 on:
April 09, 2007 - 09:17:33 AM »
my chrome one leaked as well, I ended up getting rid of the gasket and just used RTV sealer, no leaks since.
Logged
Scott - Member since 9/18/2005
ted
Sr. Member
74 cuda, 70 challenger r/t
Reply #14 on:
April 09, 2007 - 11:06:16 AM »
Napa sells a replacement non chromed housinhg.
Logged
Print
Pages: [
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
