Author Topic: Glass cleaning help  (Read 1642 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
Glass cleaning help
« on: April 08, 2007 - 10:18:48 AM »
What is the best way to remove the years of crude that has built up on me window glass. I've tried windex, soap and water but still have layers of dirt I can't get off.
« Last Edit: April 08, 2007 - 10:23:13 AM by Tropicalcats »
SOLD
Offline Oldschool
  • Member Since 9-05-06
Re: Glass cleaning help
« Reply #1 on: April 08, 2007 - 10:26:23 AM »
I have heard that you can get that somewhat cleaner by using a very mild abrasive such as toothpaste and a very soft cloth.  Apply and rub out with the cloth then use damp rag to clean the toothpaste off and then use windex or similar cleaner to complete the job. I havn't used this method, but I heard it works fairly well.    Good luck.....    :cooldancing:
Ken  --  In Georgia
Offline 67vertman
  • Member since 9-23-2005
« Reply #2 on: April 08, 2007 - 11:18:01 AM »
I have had luck using "Bar Keepers Friend" or "Bon Ami".  You can find them at Wal-Mart or your local grocery store where the sell kitchen cleaning supplies. These are non abrasive cleaner, kind of like Ajax but without the abrasiveness. Wet the glass and sprinkle a small amount of cleaner on it and use some 00 steel wool.  Apply a little pressure and rub in a circular motion.  Rinse with clean water, and it should look like new.
« Reply #3 on: April 08, 2007 - 11:43:51 AM »
Good ole fashioned razor scraper would do a world of good fast. Presoak with vinegar.
Offline 71FJ6
« Reply #4 on: April 09, 2007 - 04:56:16 AM »
I have a kit from Eastwood that is used to polish and remove very fine scratchesfrom glass.It works but is a VERY slow process.
Offline matt63
« Reply #5 on: April 09, 2007 - 07:14:22 PM »
This works.  I removed overspray from my glass using a flat razor.
Matt in Edmonton
'68 Valiant
Offline 71bigblock
    • Steve's Mopars
« Reply #6 on: April 10, 2007 - 04:26:58 PM »
Was it sitting in that pool?   :poopoke:
 :roflsmiley:
Seriously, some good advice, guys   :cheers:
Offline pettybluecuda
  • www.cudaregistry.com
    • 70-74 barracuda-cuda' registry
« Reply #7 on: April 10, 2007 - 05:52:28 PM »
A flat razor blade and some spray glass cleaner to lube it...works wounders.
« Reply #8 on: April 10, 2007 - 06:00:33 PM »
I use very fine steel wool. It doesnt scratch the glass and comes out very clean and smooth. Make sure you use the extra fine. If you try it , you wont look back. Works good on the chrome too. Doesnt matter if its overspray or window tar :2thumbs:  Not brillow pads but steel wools (extra fine)
Geesh, proof reading this sounded like a commercial :roflsmiley:
« Reply #9 on: April 10, 2007 - 06:10:13 PM »
And now a word from our sponsor. :roflsmiley:
I appreciate all the great ideas.
SOLD
Offline matt63
« Reply #10 on: April 10, 2007 - 09:06:42 PM »
Now if someone could just come up with a way to remove the scratches out of my side glass :clueless:
Matt in Edmonton
'68 Valiant
« Reply #11 on: April 10, 2007 - 09:19:31 PM »
Eastwood sells kits......let me know how it works out for ya.....hear it's very time consuming.
http://eastwood.resultspage.com/search?p=Q&ts=custom&w=glass+scratch
Offline 71bigblock
    • Steve's Mopars
« Reply #12 on: April 12, 2007 - 11:32:28 AM »
Ive heard its junk and that it makes the glass kinda wavy.  I head that awhile ago, and I dont remember who said it, so, who knows.   :walkaway:
Offline Stacked440
« Reply #13 on: April 12, 2007 - 03:48:46 PM »
Lacquer thinner?  I use that everything except plastic...takes anything off.  Just wear gloves, stuff dries out your skin and when it gets in cracks, watch out :thumbsup:
-Kyle-
