Author Topic: '73 Challenger: Should a 440 have both 5/8 and 1/2 heater hoses?  (Read 984 times)
Offline Grec
My car currently has 5/8 Napa heater hose on both the in and out.
From what I've seen, they should be mixed... one 1/2 and one 5/8. No?
I need to replace it all anyway since it's cut too short to route it correctly. I figured I might as well do it "correctly". :-)
Thanks.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Re: '73 Challenger: Should a 440 have both 5/8 and 1/2 heater hoses?
« Reply #1 on: April 11, 2007 - 08:57:39 AM »
the heater core porrbably has 5/8 for both , just change the fitting in the water pump so you can run 5/8" on both at the engine
Offline Grec
« Reply #2 on: April 11, 2007 - 10:21:33 AM »
Hummm...
That may have already been done.
I took a look at the fittings and I didn't see any of the bowing you'd expect with a larger diameter hose being clamped to too small of an outlet.
I'll double check.
Was both hoses being 5/8s something that was changed through the years, or is it just a remnent of my car's original 340 engine?
ie: did earlier Challengers all have 5/8 & 1/2 or did it vary by engine?
- 440 Six Pack
Offline dtedler
« Reply #3 on: April 11, 2007 - 02:21:33 PM »
All '73 call for 1/2" and 5/8" hoses.  The water pump on a small block is for 1/2".   If the heater core is 5/8" on both....what....whats it out of?  I just changed mine and it was 1/2" and 5/8".
Offline Grec
« Reply #4 on: April 11, 2007 - 07:00:34 PM »
Car is a 73 Chally that originally came with a 340 4bbl.
It now has a 68s 440 in it.
Both lines are 5/8 and neither look like a 5/8 hose clamped to a smaller 1/2 inlet. I'm assuming a 25% difference would be noticible. No?
It wouldn't be the 1st hodge-podge thing I've had to undo on this car. :-)
- 440 Six Pack
