Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Lower control arm
« previous
next »
Print
Pages: [
1
Author
Topic: Lower control arm (Read 804 times)
TreeFrog
Resident
Can Ya HEMI Now! If you can't dodge it Ram it!
Lower control arm
on:
April 11, 2007 - 11:55:48 AM »
my Challenger(72)
has drums on the front. I would like to eventualy change them to disks.
I want to install a sway-bar...
wheer would I find lower control arms that have the proper connection?
I understand a 73-4 will bolt right on, but figure it will be hard to find (or afford them)
Logged
65 Satellite 361 Ruby Red Poly
72 Challenger 360 Top Banana
73 Challenger 340 Triple Black
87 Dodge Ram 318 Blue
88 Dodge Ram 360 Grey (+)
HP2
Resident
Re: Lower control arm
Reply #1 on:
April 11, 2007 - 12:03:53 PM »
Easiest way to do this is to make/buy a heavy duty L bracket, drill a hole in each end of it, then bolt it to the bottom shock bolt. The end link bolts to the other end of this.
Or you can buy repop brackets and weld them to your arms.
Logged
Stacked440
Sr. Member
Reply #2 on:
April 11, 2007 - 12:30:26 PM »
my disc brake passenger side LCA was seriously bent, I had a drum LCA laying around so I cut the bracket off my bent one and welded it on the other one, works great
Logged
-Kyle-
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
April 12, 2007 - 03:04:23 AM »
It is far easier to just weld a bracket to the arms for the sway bar
Logged
TreeFrog
Resident
Reply #4 on:
April 12, 2007 - 05:26:02 AM »
as in a home made bracket, a used on, or after-market
Logged
HP2
Resident
Reply #5 on:
April 12, 2007 - 09:01:34 AM »
As in a new reproduction part.
check here.
http://scarebird.com
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Lower control arm
