Author Topic: steering play  (Read 797 times)
Offline 70challengerrt
steering play
« on: April 11, 2007 - 05:56:03 PM »
I have about 1/8 turn play in my steering wheel going down the road. Can I fix this by adjusting the worm gear(the nut/flat screw on the top of the gear box) or do I have to replace the box. I also seen some guys posting about replacing it with a box out of a cop car.
Offline djdmotorsports
Re: steering play
« Reply #1 on: April 11, 2007 - 06:42:38 PM »
Yes you can, as to how much adjustment is left youll have to find out. NYS inspection is 3 inches of free play in manual steering boxes, try to get it around 1.25 inches, prevents binding things up in the steering box. Power steering is 2 inches, but less is better with those.
1966 Plymouth Valiant V200
1973 Plymouth Barraucda
Offline Stacked440
Re: steering play
« Reply #2 on: April 11, 2007 - 10:15:31 PM »
Might want to check the coupler between the steering shaft and the box, I've seen them wear out before and cause your symptoms.
-Kyle-
Re: steering play
« Reply #3 on: April 12, 2007 - 03:05:49 AM »
if the coupler has ever been apart the "shoes" inside the couple could have been installed 90* out , this will cause a lot of play in the steering
