Author Topic: What does the voltage limiter control?  (Read 1092 times)
Offline Super Blue 72
    • Phil's Super Blue '72
« on: April 12, 2007 - 07:13:08 AM »
Hi guys, just a goofy question I wanted to throw out to you guys.  Thanks in advance!  :thumbsup:
On my car ('72 Challenger, Rallye gauge cluster), the fuel sending unit wire has no voltage to it (checking from the tank and grounding) and the temperature gauge doesn't work and has a new sender.  I didn't check yet if there's voltage to the gauge or not.  The oil pressure gauge DOES work.
Question is:  Does the voltage limiter (Is that what it's called that provides voltage to the gauges?  From 12v to 5v?) provide voltage to all 3 gauges or just the temp and fuel gauge?  :clueless:
Thanks a bunch!  :)
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
Re: What does the voltage limiter control?
« Reply #1 on: April 12, 2007 - 08:13:54 AM »
provides 5 volts to all three of the gauges- only difference is if you have a low fuel option- then the low fuel relay provides it's own power.
idiot lights use 12 volts to run!!!
« Reply #2 on: April 12, 2007 - 09:00:35 AM »
Cool!  Thanks for the reply!  :thumbsup:
I'll have to check out the fuel and temp gauge situation in more detail.   :working:
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #3 on: April 12, 2007 - 12:27:38 PM »
THE  wire to the fuel sending unit is the ground for the gauge, has no power.
« Reply #4 on: April 12, 2007 - 01:22:02 PM »
 :clueless:  Doesn't the 5v reference voltage travel through that wire and the fuel tank sending unit vary the resitance?  :dunno:
So if I check for voltage on that wire it should be 0v, not like 5v or something?  Thanks!
Offline 71 DEPUTY
    • Cardomain
« Reply #5 on: April 12, 2007 - 01:42:48 PM »
check one side of the limiter- should be 12 volts
check case of it- should be grounded
the other should be pulsing- it averages out to be about 5 volts.
*** note- if the dash is out of the metal dash frame- you will have to ground the dash to the frame as the voltage reg. will not work. It's a good idea to add a ground this way as the voltage reg, all the bulbs, tach, dome light switch and the wiper switch needs a ground to work!!!!
John Mac
« Reply #6 on: April 12, 2007 - 01:48:01 PM »
Cool, thanks John!  :thumbsup:
Something to play with once the sleet stops!
