Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
rear brakes locking up.
« previous
next »
Print
Pages: [
1
Author
Topic: rear brakes locking up. (Read 685 times)
70challengerrt
Jr. Member
on:
April 12, 2007 - 07:24:01 PM »
I have a 69 roarrunner with 10" brakes. Every time I back up the adjusters tighten the brakes to much so when you try to go forward the right rear is locking up. The motor can turn it but not easy. I readjust and the same thing happens. My next thought was to remove the adjusters. With out them I could just adjust them in spring and I think that would work for the summer. Any thoughts?
Thanks
Todd
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: rear brakes locking up.
Reply #1 on:
April 13, 2007 - 12:11:49 AM »
Have you replaced the springs , if they are weak the shoes could be moving too far in reverse , you certainly can remove the self adjuster cable & run without them but you have to check the adjustment or the pedal will drop down towards the floor
Logged
Mt.St.BigBlock
Jr. Member
Reply #2 on:
April 14, 2007 - 01:01:31 PM »
Hi, I had a 73 charger that would do that. Turned out to be a rusty e-brake cable going to
that wheel that wasn't returning all the way when the e-brake was released...causing the
adjuster to go crazy until it would lockup.Jeff
Logged
71 cuda 383 3spd manual gy9
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
April 14, 2007 - 10:50:19 PM »
a friend just had the exact same situation today , it was an issue with the E brake cable
Logged
70challengerrt
Jr. Member
Reply #4 on:
April 16, 2007 - 07:22:39 PM »
That was it the passenger e brake cable was froze and locking it up. I replaced the cable and wala.
Thanks
Todd
Logged
Oldschool
Administrator
Permanent Resident
Member Since 9-05-06
Reply #5 on:
April 17, 2007 - 06:47:09 AM »
I'm glad you found the problem and it was such an easy fix....
Logged
Ken -- In Georgia
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
