As most of you are aware.. my cuda was taken down to bare metal.. and there's no rust, thankfully. I will be attending to most of the easier body work.. except the org shaker hood. It appears (because of 2 weld lines) that the hood must of popped open once while racing.. becasue there are waves in the metal.. so i'll need an expert to make it look "smooth" again.
However, the body has some dings here and there and some deep sand scratches. So my question is what is the best mud for workability and for durability?? Also, the original rear quater lips were pulled out slightly, so I have to perfect the contour as was done before I took it down to metal. I'm began to use a 7/16 gas hose wrapped with sandpaper to get the desired contour.. and other suggestions? or better suggestions? TIA
71fish
