Author Topic: Carb to Fuel Pump Lines  (Read 530 times)
Offline Winston
« on: April 13, 2007 - 08:34:56 AM »
I need to buy some.  The thing is...I have a Carter AFB on the car.  Does anyone know if the carb to fuel line sets for the AVS work on the AFB?  If not, what are my options?  Make my own?  I did notice that my AFB has a threaded fitting with a nipple on it where it accepts a hose rather than a line with a fitting like what threads into an AVS.
Thanks for any advice!
nivvy
Re: Carb to Fuel Pump Lines
« Reply #1 on: April 13, 2007 - 09:03:08 AM »
Just buy a carb inlet fitting.... I believe your threads are the same as an edelbrock.... or you can just hook up a rubber fuel line to that fitting you describe down to the pump !
« Last Edit: April 13, 2007 - 09:05:35 AM by StrOkEr »
