Author Topic: Emmisions and aircleaner vacume routing  (Read 802 times)
Offline farmboy70
« on: April 13, 2007 - 11:36:27 AM »
Doe's anyone have a diagram for a 73 Cuda 340
Re: Emmisions and aircleaner vacume routing
« Reply #1 on: April 14, 2007 - 07:59:42 AM »
this what you need?
« Last Edit: April 14, 2007 - 08:10:40 AM by bullitt99 »
Offline farmboy70
« Reply #2 on: April 14, 2007 - 12:41:25 PM »
That is what I needed but I also need to know where the vacumn is hooked for the air cleaner flap door?
Thanks again
« Reply #3 on: April 15, 2007 - 03:45:01 AM »
this looks correct. hose to carb. about 6" long
« Last Edit: April 15, 2007 - 04:06:58 AM by bullitt99 »
Offline farmboy70
« Reply #4 on: April 15, 2007 - 07:23:03 AM »
Do I have the wrong air cleaner then? Mine has a air flapper door inside the where the filter is for cold air intake.
On another item I want to add a fan shroud but the rad has no mounting provisions, is there supposed to be a clip in the side holes of the rad tanks for this on a 73 Cuda.
I'm sure I have the wrong size fan blades for a shroud but I will change that.
« Last Edit: April 15, 2007 - 08:52:53 AM by farmboy70 »
« Reply #5 on: April 15, 2007 - 09:17:36 AM »
I've never seen one with the extra flapper. My '73 340 Challenger was like the pictures I posted.
mancinni has add on brackets for 22" radiator shroud. as well as OE style shroud (mine did not come with shroud)
http://chucker54.stores.yahoo.net/rafansh.html
