Author Topic: Vibration question  (Read 4873 times)
Re: Vibration question
« Reply #15 on: April 19, 2007 - 12:56:56 AM »
Typically vibrations that ast like that are tire / wheel or driveshaft vibrations
 you could try a hose clamp or 2 at each end of the drive shaft & move the worm gear to different postions around the drive shaft to see if it changes the vibe
Offline Bearcuda
« Reply #16 on: April 19, 2007 - 02:54:26 AM »
Also check for any irregular tire wear patterns caused by lack of rotation or alignment issues. Slight feathering on the tires could even cause a vibe at that speed.
1973 Cuda 440
1971 Javelin SST
Offline moper
« Reply #17 on: April 19, 2007 - 09:45:09 AM »
You should be able to make it come and go lower in rpm that way. It sounds like a driveshaft a hair out of balance, but tires can do it too. Also, make sure the tires are high speed balanced. The shop wont spin to 110 I think "normal" speeds are 40mph on a balancer. That may not be good enough for your speeds.
Offline Bearcuda
« Reply #18 on: April 20, 2007 - 06:17:22 AM »
High speed balance is a misnomer. Balanced are balanced as long as they are done right. A lot of our customers try and complain about the speed of our balancer when they see how slow it goes with the road force roller on it. I try and explain the same thing to them.
1973 Cuda 440
1971 Javelin SST
Offline moper
« Reply #19 on: April 20, 2007 - 10:09:36 AM »
Well, I'd respectfully disagree. A tire that is perfectly in balance, you are right about. Most tire shops I watch (and I have several I deal with all the time) dont have the equipment to spin the tires that fast. It's for safety and efficiency. Most cars will not spend their time cruising with wheel speeds in excess of 100mph. Centrifical force will increase the "felt" weight exponentially as the tire's rpm increases to 3-4 times the tested rpm. A tire in balance at 120mph is in balance at 40. A tire in balance at 40mph may not be in balance at 120. I dont think the pressure exerted on the tread will change the weighting. It might change the way the tire reacts at speed, but the masses involved dont change. Just the shape of that mass. :clueless: :dunno:
Offline Bearcuda
« Reply #20 on: April 21, 2007 - 02:33:17 AM »
Well, I have been dealing with balance issues first hand for 15 years and that how the Hunter balancer salesmen explain it too. I had to go to a special class just for our balancer with road force capabilities. We are the only shop in a 200 mile area that has one and many dealers have brought vibe problems to me that I have fixed.
1973 Cuda 440
1971 Javelin SST
Offline moper
« Reply #21 on: April 25, 2007 - 06:06:28 AM »
Then I defer to you sir  :worshippy.
We didnt have that fancy stuff when I started dealing with these issues. And I've never seen one either...lol. I've also learned how much a good salesman is worth. :roflsmiley:
Offline Bearcuda
« Reply #22 on: April 25, 2007 - 06:26:50 AM »
I just reread my post. I didn't mean to come off all superior sounding. It's just that I've dealt with these issues for some time now. Sorry for sounding rude about it.
1973 Cuda 440
1971 Javelin SST
Offline moper
« Reply #23 on: April 25, 2007 - 06:36:35 AM »
Not rude at all. And I wasnt "typing sacrcastic". I feel you know more than I do about it...lol. I learned something from the thread. That's why we're all here. :2thumbs:
« Reply #24 on: April 25, 2007 - 06:40:40 AM »
Could be a slightly out of balance tire being magnified by harmonics. As the slight deflection of the suspension recovers IF the out of balance point is in phase at that moment the next deflection is increased, as speed is increased it goes back out of phase & becomes less noticeable.
Offline Bearcuda
« Reply #25 on: April 25, 2007 - 06:53:34 AM »
Your views are intriguing to me and I wish to subscribe to your newsletter.
1973 Cuda 440
1971 Javelin SST
« Reply #26 on: April 25, 2007 - 06:58:08 AM »
I'll admit it's a long shot. SEND Dollar &  A SASE to.....  :woohoo:
my concept comes from watching out of balance washing machines as the speed up there is always a point that they shake like crazy (hopefully at very low speed) before smoothing out & the phase thing is the reason.
« Last Edit: April 25, 2007 - 07:03:02 AM by bullitt99 »
Offline Bearcuda
« Reply #27 on: April 25, 2007 - 07:03:17 AM »
 :smilielol: :roflsmiley:
1973 Cuda 440
1971 Javelin SST
Offline tactransman
« Reply #28 on: April 25, 2007 - 07:13:48 AM »
I'm in too! :roflsmiley:
Terry-tactransman
Union, Mo.
« Reply #29 on: April 26, 2007 - 12:37:44 AM »
the other balance problem can be pinion angle , if the nose of the diff is too high it will vibrate
