Author Topic: Dist. wear  (Read 686 times)
Offline 71bigblock
    • Steve's Mopars
Dist. wear
« on: April 15, 2007 - 01:44:56 PM »
Just wondering how to repair the slop in the distributor shaft.  Its got quite a bit of wear.  Pretty sure its part of the cars hesitation problem.   Are there bushings in the top and bottom?  Ive never had one apart.  Will the shaft be wore at all, or do the bushings mostly wear?  Its on a '71 383.  Thanks   :cheers:
Re: Dist. wear
« Reply #1 on: April 15, 2007 - 04:24:28 PM »
the bushings are bronze so the shaft will be ok , there are 2 bushings , one near the top & bottom of the housing
Offline 71bigblock
    • Steve's Mopars
Re: Dist. wear
« Reply #2 on: April 15, 2007 - 07:39:30 PM »
Thats good news CP, thanks!  Afternoon job, or a few hours?   Hard?
Thanks again   :2thumbs:
Re: Dist. wear
« Reply #3 on: April 16, 2007 - 09:18:15 AM »
not very difficult , you need to undo the vacuum advance & aadvance plate [ 4 screws ] & drive the roll pin out of the lower shaft & slide off the nylon ring that limits upward travel of the shaft , & remove the small circlip inside the top shaft , there is a small piece of jute like material in the top of the shaft & the circlip is under that , then you will have a bare housing & can get to the the bushings
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Dist. wear
« Reply #4 on: April 16, 2007 - 09:36:26 AM »
I have worked on one also, and I agree with Chryco, it is not very hard, just be careful you get everything back together correctly.  Time wise, it really depends on how good you are with taking things apart.  Even if you are real slow, you should be able to do in an afternoon.  Good Luck.   :2thumbs:
Offline 71bigblock
    • Steve's Mopars
Re: Dist. wear
« Reply #5 on: April 16, 2007 - 11:24:32 AM »
Perfect.   :2thumbs:
Thanks guys.  I hope this helps my hesitation/rough idle problem.  I should be able to do that in about an hour.  I've taken a thing apart, or two...
 :bricks1:
Offline 71bigblock
    • Steve's Mopars
Re: Dist. wear
« Reply #6 on: April 16, 2007 - 04:09:36 PM »
Ok, so I called the dealer.  He said that he couldnt find it in the book.  ( I think he's a Chevy guy, not kidding)  He said he found this in the performance catalog though:
http://www.mopar.com/m_perf_subcat2Check.jsp?SubSubSubGrpID=361&dummy5=1176762290718
Is that right?  Do I need two?  Now I'm really confused.   :1zhelp:
