Author Topic: Sikkens paint over PPG DP90 ...Any Problems??  (Read 1543 times)
Offline Confederate Cuda
« on: April 16, 2007 - 07:03:07 PM »
Can some of you paint experts out there tell me if you think that shooting Sikkens paint over a PPG primer would be a problem? I have seen other posts on other sites where people have had problems mixing brands of primer and paint. Is this a real issue or are these guys just loyal to a brand and listening to a sales rep.??
Offline 70challengerrt
Re: Sikkens paint over PPG DP90 ...Any Problems??
« Reply #1 on: April 16, 2007 - 07:11:35 PM »
I have never sprayed sikkens so I can't say anything one way or another. With that said I have sprayed several other brands and ppg does lay the nicest. IMO. As far as problems I don't know. The best way to find out is to spray a valance or something small.
Offline 70_challenger
  • Suburban Detroit, Michigan
« Reply #2 on: April 16, 2007 - 08:43:07 PM »
Unfortunately, I am not a 'paint expert' by any means, but that is exactly what is on my car...Sikkens over DP90.
The bodyshop did sand off quite a bit of the DP, while doing the bodywork, and they touched it up with some Akzo-Nobel (Sikkens) primer, but the paint covered both primers the same.
Since my DP had been on the car for over a year (after media blasting), they did have to scuff and re-coat part of it...Apparently, you don't have long to cover the DP, once it is sprayed on there.
Good luck with your project!
-Tom
Offline jvike
  • Pro-Touring Cuda
« Reply #3 on: April 19, 2007 - 06:26:53 AM »
My car is painted with Sikkens products. My body shop guy said that there should be no problems painting on a primer from a diffrent brand.  :2thumbs:
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #4 on: April 19, 2007 - 07:02:02 AM »
Any paint manufacturers recommend thier conmplete system be used but I have used plenty of different brand primers,sealers and topcoats and never had a problem.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
