Author Topic: Pics requested: 4-speed bracket for Z-bar & 4-speed hump underside  (Read 6684 times)
Offline ragtopdodge
Can someone please provide some good, clear, big somewhat, pics of where the bracket goes on the front frame rail?
I think it goes where there's this tab on the bracket that it kind of fits into a slot on the frame rail on the topside.
Also, when cutting for a four-speed hump, how much do you go in from scribing around the hump?  1"?  Can someone provide good pics installed both top and underside (w/o the tranny installed)?
Thanks.
 :swaying:
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Re: Pics requested: 4-speed bracket for Z-bar & 4-speed hump underside
« Reply #1 on: April 18, 2007 - 12:31:22 AM »
I generally cut approx 1" inside the line around the floor hump , the frame braket lines up with the Oval hole sorry no pix handy
Offline farmboy70
« Reply #2 on: April 18, 2007 - 04:52:18 AM »
Here is a picture of the underside.
Offline Finoke
« Reply #3 on: April 18, 2007 - 04:57:02 AM »
I agree. Here is some pics of my 4 speed hump install. I'm looking for pics of the bracket install too. Where did you buy your bracket????????????
Offline cudabuyer
« Reply #4 on: April 18, 2007 - 04:59:08 AM »
i love the cartoon pic of the cuda but it looks like a cross between a corvette and a cuda not a bad idea if GM buys Chrysler sorry if that comment offends anyone ??!! :eek2:
70 Dodge Challenger Convertible 6.1 Hemi
Offline ragtopdodge
« Reply #5 on: April 18, 2007 - 07:26:54 AM »
Sweet!  Exactly what I'm looking for.  Thanks a bunch.
However, what's the purpose of the raised area highlighted in red below?  You don't weld that part?  I imagine seam sealer would still cover it?
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline ragtopdodge
« Reply #6 on: April 18, 2007 - 07:29:23 AM »
As far as the bracket, this is the only pic I have, but I can't tell it's for an e-body or not.
I'll have to take a pic of my car and where I THINK it should go as it seems like the bracket would be a little further away from the firewall compared to the pic above.
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline ksierens
    • 70 Challenger Resurrection
« Reply #7 on: April 18, 2007 - 07:59:30 AM »
Here are a couple shots of my Z-bar bracket
Kurt - SE Michigan
Offline ksierens
« Reply #8 on: April 18, 2007 - 08:05:04 AM »
My 70 Challenger does not have that raised bump.  I think that the aftermarket humps have them to handle newer models floor pans. In fact, the replacement floor pan I used did have a hump in that area, but I hammered it down to match my hump.  This is starting to sound like a Fergy song  :)
Kurt - SE Michigan
Offline ragtopdodge
« Reply #9 on: April 18, 2007 - 08:15:08 AM »
I dunno.  I got an OEM hump cut out from an original car and it has that raised hump.  maybe it came off of a newer '71+ e-body???
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline ksierens
« Reply #10 on: April 18, 2007 - 08:37:21 AM »
Here is a shot of my original one.  It is an early model, maybe they changed them later  :clueless:
Kurt - SE Michigan
Offline Stacked440
« Reply #13 on: April 18, 2007 - 06:49:45 PM »
Finoke did you notch your cross member so the shift linkage will clear?
-Kyle-
Offline Finoke
« Reply #14 on: April 19, 2007 - 03:19:01 AM »
I haven't done anything yet till I do a trial fit. I have a 4 speed car in storage that I need to get up under and take some pics.
