Author Topic: B&M Shifter Cable  (Read 1092 times)
nivvy
B&M Shifter Cable
« on: April 18, 2007 - 12:22:21 PM »
Mine keeps melting  :pullinghair: the last one I installed I even put a heat shielding over it .... anyone have any suggestions or what length shifter cable do you run ???
Offline Carlwalski
Re: B&M Shifter Cable
« Reply #1 on: April 18, 2007 - 06:20:45 PM »
Run a factory Slap stik set up to be 100% safe. :grinyes:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2 on: April 18, 2007 - 06:26:37 PM »
I had this happen a few years back. I had to buy a longer one and route it buy the starter then along the oil pan to steer clear of the headers.
Tom :villagers:
Tom
« Reply #3 on: April 19, 2007 - 12:54:35 AM »
I hate the cables , they are very poorly made , if they were made with a flat wire wrap like a pedal bike shifter cable heat would not bother the cable
 When I become bored & rich I will styart making real cables along with about 100 other badly needed parts & ideas
don`t hold your breath K !!!
nivvy
« Reply #4 on: April 19, 2007 - 10:43:59 AM »
The 4 footer worked out perfect!!!  :cooldancing: not even close to the header.... was a tough bend but it all works great!!!  :burnout:
Offline dwbiggs
« Reply #5 on: May 09, 2007 - 09:03:00 AM »
Had a B&M break on me....left me sitting at work one day.  Went to factory setup after that.
