Author Topic: engine cranks but no spark  (Read 866 times)
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
« on: April 19, 2007 - 04:38:18 AM »
hey guys i finally have the engine turninig over on its own but now there is no spark???? any body have any suggestions?? it is a 72 chally 440( it tried to start one time but ever since then it just turns over with no spark)
Re: engine cranks but no spark
« Reply #1 on: April 19, 2007 - 09:05:33 AM »
Some questions...
  Is this electronic or point ignition? How did you verify no spark? If there truly is no spark, we would need to know if you have 12 volts going into the ballast resistor. So, it could be the ignition switch, ballast resistor, coil, or ignition module.
Offline WVUFELLA
« Reply #2 on: April 19, 2007 - 10:19:53 AM »
electronic ignition.......no spark meaning i cant ground the wire and plug to anything to get it to spark? it  popped one time like it was tryin to start  but then nothin  12 volts to ballast you say?? anything other voltage references i can check ???
« Reply #3 on: April 19, 2007 - 03:05:37 PM »
If you pull a spark plug wire, and hold it with insulated pliers close to ground(valve cover), you should see a spark when the engine cranks. You will need a helper for this obviously. You didn't by chance have your distributor out recently, did you? A common problem is putting them back in 180* out of phase. Sorry to get off track... if you have a volt meter, with the key in the "on" position, you should see about 12 volts going into the ballast resistor. If you pull the connector off the ignition module, there should also be 12 volts on one of the pins of the connector. This will tell us your wiring is good, as well as your ignition switch. Then we can work from there.
Offline WVUFELLA
« Reply #4 on: April 19, 2007 - 06:33:52 PM »
hey guys It finally happened!!!!! She started up and ran for a while. Granted there are still some minor timing and vacuum issues but she started up and it sounded great. We tore it apart about a 8 months ago and have been tinkering  here and there. Thanks for the help it ended up being the two wires from the dist. werent making a cood enough connection. My wiring harness was for a 318 so we had to make a extension to connect the dist to the wiring harness and that piece wasnt making a very good connection.
« Reply #5 on: April 20, 2007 - 12:15:30 AM »
 :2thumbs:
