Cooling fan and radiator questions
Author Topic: Cooling fan and radiator questions  (Read 2337 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: April 19, 2007 - 09:54:44 AM »
I just added a fan shroud and found out it didn't fit the fan (Fan shroud from Mopar Performance), I'm missing about 0.2 cm for it to clear. My 'cuda is a 383 4bbl/HP A/C car with a 26" Radiator part No. 2998 908. Don't know the fan clutch part No. is. But the Fan has 5 blades and it's part No is 4140 063. I thought all big block had a 7 bladed fan. And not a 5 blades fan. Or am I wrong?
« Last Edit: April 19, 2007 - 10:57:10 AM by widing'cuda »
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Re: Cooling fan and radiator questions
« Reply #1 on: April 19, 2007 - 02:50:45 PM »
To confuse you even more, my 440 has a six blade fan with a 26" radiator. Sorry I can't help out here.
Offline widing'cuda
« Reply #2 on: April 26, 2007 - 12:56:56 PM »
My 'cuda does not have the original engine. But it is a 70 383.
Here's a picture of the fan. I thinking of getting a 7 blade fan as it will cool the engine more.
« Reply #3 on: April 26, 2007 - 03:21:02 PM »
Yes, a seven blade fan will cool the engine more, the trade-off is a little loss in horse power, as the seven blade fan takes a little more Ooomph to turn. If you don't run hot, I'm not sure I would mess with it. Just my thoughts.  :2cents:
Offline rich
« Reply #4 on: April 27, 2007 - 05:29:01 AM »
Hey Widing,
I bought the fan for the 'cuda about a year before you owned the car; it originally had a terrible aluminum fan which did nothing. This fan has always cooled the 'cuda really well; even when we took it to Le Mans and were stuck in traffic in 30 degree C heat. If you're concerned about the cooling, I don't think it's an issue but of course if you want it to look stock, then maybe you'd need to replace the fan.
Rich
Offline widing'cuda
« Reply #5 on: April 27, 2007 - 12:33:51 PM »
Hey Rich, how are you?
Well I have some cooling problems. So I'm going to add the 7 blade fan. When I was in queue the car started to overheat, so I had to drive in the bus lane to cool the engine.
Offline Mopar73340
« Reply #6 on: April 27, 2007 - 01:04:06 PM »
If you go with the 7 blade fan be sure to get the heavy duty clutch unit to go with it. The standard clutch won't spin the 7 blade fan fast enough to work correctly. Been there!!   Just my  :2cents:
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #7 on: April 27, 2007 - 04:38:34 PM »
THAT 5 blade fan  is most likely   the one that MP sells.
Offline ntstlgl1970
  • T a c o c a t
« Reply #8 on: April 27, 2007 - 04:51:52 PM »
I agree with Ted, I bought my fan and clutch from MP and it looks exactly the same (5 blade) as yours.
Offline rich
« Reply #9 on: April 27, 2007 - 05:00:26 PM »
Yes, it is a Mopar Performance fan.
Offline widing'cuda
« Reply #10 on: April 28, 2007 - 02:16:27 AM »
Thanks I'll keep that in mind
Offline widing'cuda
« Reply #11 on: April 28, 2007 - 02:17:52 AM »
Ok, is fan clutch as well Mopar Performance?
Offline ntstlgl1970
  • T a c o c a t
« Reply #12 on: April 28, 2007 - 06:41:21 PM »
If it's the M/P clutch, mine doesn't seem to ever lock the fan clutch until the temp gets to 200 or so. Once it does "lock up" it definitely moves some air even with the 5 bladed fan. You could get a fan clutch from a parts store like autozone or kragen for a early (70's) pickup and try that. The clutch on my 73 D200 locked up at about 175 or so, think I paid about35 -40 bucks for  mine.
