Author Topic: XV Motorsports' lower radiator support brace...  (Read 2633 times)
Offline ragtopdodge
« on: April 19, 2007 - 11:00:28 AM »
On XV's site, it APPEARS that the whole lower radiator support was removed and replaced w/the stiffening brace???
WHile some has kept it?
Any pros/cons to either method?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline TrakHor
Re: XV Motorsports' lower radiator support brace...
« Reply #1 on: April 19, 2007 - 06:11:39 PM »
They each have their pros and cons. I personally would choose the second methond given the choice. Just to keep from disturbing the original metal.
J
Offline SilverChally
« Reply #2 on: April 20, 2007 - 11:22:10 PM »
Well the stock rad wouldnt be able to sit down in fully with the stock piece still there.  There was soe discussion about this before.  I like the look with the factory piece there, but theres the rad issue.
70 challenger project
68 satellite
Offline ragtopdodge
« Reply #3 on: April 21, 2007 - 11:38:15 AM »
Really?  So the radiator won't fit if you leave the stock piece in?  I ordered it so maybe it'll come w/instructions.  XV hasn't been responsive to my e-mails. :stomp:
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #4 on: April 21, 2007 - 08:34:19 PM »
Thats my understanding from what I read, plus look it obviously is a few inches above the bottom of the rad support.
68 satellite
Offline TrakHor
« Reply #5 on: April 23, 2007 - 01:08:00 PM »
Good point. I didn't think of that since I'm not running a stock rad, my configuration is different.
Offline Kapteenikosmos
« Reply #6 on: May 24, 2007 - 10:36:03 AM »
Do I run into problems with clearances if I fabricate some stiffening below the original lower radiator support? Is there supposed to be anything under it? Even with couple of inches thick brace the lowest point of the car should be elsewhere? I have hard time imaging how it would be because it's the first e-body I've working with and its almost two years when I took it apart.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
