Author Topic: kickdown linkage adjustment  (Read 11550 times)
Offline tactransman
Re: kickdown linkage adjustment
« Reply #15 on: April 22, 2007 - 06:59:55 PM »
If it is not shifting down to low manually,you have something up inside. drop the pan.
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #16 on: April 22, 2007 - 07:06:25 PM »
Terry-tactransman
Union, Mo.
nivvy
« Reply #17 on: April 22, 2007 - 09:16:01 PM »
The lokar kit is the way to go!!!!! or just put in a manual valve body like me ....  :burnout:
Offline dwbiggs
« Reply #18 on: April 24, 2007 - 12:06:59 PM »
Quote
What advantage does manual valve body give you...may want to try one myself.  :2thumbs:
Offline tactransman
« Reply #19 on: April 24, 2007 - 01:32:46 PM »
Maximum pressure (squeeze) on the clutches and bands all the time. Firm shifting for the street though. :grinyes:
Terry-tactransman
Union, Mo.
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #20 on: April 24, 2007 - 02:34:26 PM »
Is there nowhere to get the original linkage rod?  I don't really trust using a cable to push a linkage - cables are made to pull.  I can't find anything on ebay, year one, or even just googling it...
Offline 70challengerrt
« Reply #21 on: April 24, 2007 - 04:54:57 PM »
It depends on what setup you want. The solid rod that runs from the throttle linkage right the tranny you can find in most salvage yards. The 3 piece style with the pivot on the bellhousing is harder to find(at least around here).
Offline tactransman
« Reply #22 on: April 24, 2007 - 05:52:49 PM »
The cables don't push,they pull. They mount to the other side of the tranny lever and pull.(Just like the OEM cable on a Dodge Ram PU)
Terry-tactransman
Union, Mo.
« Reply #23 on: April 29, 2007 - 05:37:01 AM »
You guys were right it was internal. I went through it and adjusted everything according to the book and it still wouldn't shift so I pulled it and used one I had laying around. I now works great. So much for the freshly rebuilt one. Thanks for everyones help and suggestions.
Todd
Offline JayBee
« Reply #24 on: April 29, 2007 - 01:50:01 PM »
Thanks for filling us in on the final solution. You never know when someone else is  :horse: and  :pullinghair: with a similar problem.
John
1970 Barracuda convertible
2014 Toyota Avalon
