Author Topic: Race Ready Big Block 383 for Trade  (Read 1496 times)
Offline moparmaniac59
  • Drive it like ya stole it!
« on: April 19, 2007 - 07:10:08 PM »
I have for trade a 1969 Big Block 383. :burnout: I would like to trade it for a race ready Torqueflite 727 automatic transmission and stall converter, preferrably reverse manual valve body with an approx 3200 rpm range torque converter for my 440 big block. The 383 is a 1969 block, bored .030 over. Steel crank, stock rods with full floating wrist pins and ARP Wav-Loc bolts with 12.5 to 1 TRW forged dome pistons. The block has been painted in the lifter valley and crank area with Rustoleum industrial red paint on all of the non-machined areas. The crank is a stock steel crank turned .010" with a factory harmonic balancer. It has a high volume Melling oil pump (new) and a stock 6 quart oil pan with windage tray. The camshaft is an Ultra-Dyne 613 lift int/ex, duration @ 50" is 276 int/ex with a lobe separation of 108 and advertised duration of 309 int/ex. Springs shipped with the camshaft and with titanium retainers with 3/8" chrome moly pushrods. Isky ductile iron adjustable rocker arms. it has 906 cylinder heads with max porting with 2.14/1.81 valves. Chrome Mopar performance tall valve covers. Brass freeze plugs in the heads and block. Torker intake. This setup was in a '68 Dodge Dart that ran low 11's in the 1/4 mile, all throttle, no bottle. Tried it on a bottle one year it it ran mid 10's. It has been pulled, disassembled, inspected, freshened up and is ready to go!! This would make a good trade and I'm sure cost much more to build than a tranny setup for a moderate strip/street application would cost to build. If interested, you can call me at 757-305-8369 (cell) or email me at mopar1968@netzero.net. I prefer a local trade. I live in Portsmouth, Va which is about 25 miles from VA Beach. If you are out of the area, and really interested, I am sure we can work something out!  :2thumbs:
                                                           Matt B.
Matt
Offline Tim440RT
  • Get an R/T
Re: Race Ready Big Block 383 for Trade
« Reply #1 on: April 24, 2007 - 04:11:56 PM »
I got a 727 with a standard pattern valve body, its got a shift kit and was drilled out. Its got alto race clutches in it. It's got an 11 inch B&M converter i dont remember the stall off the top of my head. It's got a deep aluminum pan and a cheetah shifter with the linkage cable and everything. Ran it in my 440 challenger, it was pretty streetable, just had a little kick when it would shift at low rpms, and under hard throttle it would chirp gears pretty hard. Let me know if your interested, im going to the nascar race in Richmond in 2 weeks... Tim
1970 Challenger R/T 440
« Reply #2 on: April 24, 2007 - 05:15:30 PM »
Hey Tim,
I sent you a PM.  :2thumbs:
                                                       Matt B.
Matt
