Author Topic: small block dilema  (Read 551 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
small block dilema
« on: April 20, 2007 - 12:38:49 AM »
I was going to stick my 70 340 into my 72 challenger, but since I got that 70 challenger, it is going to go in that instead. SO now I have a situation. I wasnt to build a serious stroker. I have a set of x heads and I have a set of marine competition 6 pack carbs, I also have like 3 70 318 blocks. Do I use one of those and stick a 4.00 inch crank in it, or am I better off finding a 360 block, or a new 340 block from mopar? By the way I am looking to clear 500 hp, and 8k rpm.
1996 Dodge Viper GTS Coupe
Re: small block dilema
« Reply #1 on: April 20, 2007 - 01:09:29 AM »
for the cost of a 360 block Why consider a 318 at all
if you have a real budget to work with I would seriously look at an R3 Mopar block stroked  which can make 700 hp range with reliability & it fixes a lot of the little issues with std LA blocks
Offline 72hemi
« Reply #2 on: April 20, 2007 - 07:42:47 AM »
Does that block accept standard heads and intakes. Also should I use my x heads, or go with something like mopars large port aluminum commando heads?
« Reply #3 on: April 20, 2007 - 08:29:03 AM »
The R3 block can use std heads but if you seriously want 500 HP why limit yourself to stock heads , the R3 is really designed to use 6 bolt / cylinder heads
 The 308 truck castings ported will make 40 RwHP or 60+ gross HP more then the X head
Offline 72hemi
« Reply #4 on: April 20, 2007 - 08:31:27 AM »
Thanks!
