Question on vaccum advance
Author Topic: Question on vaccum advance  (Read 1047 times)
Offline Grec
« on: April 20, 2007 - 08:01:59 AM »
My car is a 73 Challenger with a 4bbl 440. It's got an MSD unit on it. Not sure which distributor I have.
I am currently converting it over to a six-pack.
One of the things I have noticed is that my vaccum advance is capped at the disctubutor and therfore disabled.
I'm thinking that when I hook up the six-pack I should dial back the timing (it's currently at 5 BTDC) and hook up that vaccum advance.
Car has always had horrible mileage and ran rough in the low RPMs. Could the lack of vaccum advance caused any of this?
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Re: Question on vaccum advance
« Reply #1 on: April 20, 2007 - 08:32:07 AM »
generally I do not use the vacuum advance feature as it will run better & increase milage without it , but with it disconnected you need to set your timing at 36* total at about 3000 rpm , this should give you approx 16* at idle , just settting the timing closer to 16* at idle should make it run a lot better
Offline Dave-R
    • Challenger Message Board
« Reply #2 on: April 20, 2007 - 08:49:29 AM »
I completely agree. No 440 should have less than 12 degrees at the very least. The engine will also run cooler (and less smelly) at 14 degrees or more.
36* @ 3000rpm can just be a touch too much on some high compression/low octane fuels but even then 34* will be enough.
If you have 36* total and your idle advance is below 14 degrees then you should consider limiting how much advance you have in the distributor.
You could still use the vacuum advance as well. It should give you a touch more MPG and help keep the plugs clean. BUT with the mechanical advance set like this you would have to limit the total vacuum advance to around 10 degrees so it is hardly worth it and more hassle than it is worth.
Offline Grec
« Reply #3 on: April 20, 2007 - 09:39:13 AM »
<scratches head>
The stock spec for a 440-6 is supposed to be 0 according to what I've read.
You're saying I should bump it all the way up to 16 at idle?
This isn't going to give me possible detonation issues at WOT?
Forgive me, I'm used to working on japanese motors where jumping that much would be bad news.
- 440 Six Pack
Offline Autophile
  • Kowalski... and the keys to a sawed-off weekend!
« Reply #4 on: April 20, 2007 - 10:41:51 AM »
The first step in tuning your distributor is finding out what timing settings you have right now. An adjustable timing light (or timing tape on your balancer) will help you. Here are the steps:
1) Leave the vacuum advance canister port disconnected/capped. Make sure that there are no open vacuum ports on your carb(s) or intake manifold.
2) Take a timing reading with the engine running at idle. This is your initial timing, which I understand is currently 5º advanced.
3) With the timing light still attached, increase engine speed until the timing reaches a maximum value. You may find that your ending point value (i.e., total advance) will be something like, for example, 32º @ 3200 rpm.
The best settings for your particular engine will depend on many factors, such as compression ratio, age, camshaft specs, and available fuel quality. The basic guideline is to have the maximum timing advance possible across the entire rpm range without detonation (pinging). The maximum realistic initial advance will be ~15º (limited by your starter's ability to crank over the engine), and the maximum realistic total advance is 35º. So, you want an initial timing setting of 15º, a mechanical advance range of 20º, and you will want this range to climb as quickly as possible without detonation. The magnitude of the advance range is set by one or more small bushings inside the distributor. The rate of the advance is set by small springs inside the distributor.
Adjust your initial timing to 15º advanced. Confirm that your total timing is 35º advanced. If your total timing is less than 35º, change the bushing(s) in the distributor to get the 20º range. Confirm that your total advance is reached at ~3000 rpm. If it is all in by 3000 rpm but you experience pinging when driving, then either increase fuel quality or change the springs to slow down the advance rate.
Another way to deal with mechanical timing is to just lock out the distributor timing advance mechanism and leave the timing at 35º advanced. For this, you will need to install an engine start retard switch which will automatically retard your timing 20º when starting the engine. This is the way I run my mild street 440, and I enjoy it this way.
Vacuum advance is separate from mechanical advance. It does not change the maximum power output of your engine, it is just a driveability tuning tool. It only affects the "part-throttle" characteristics of your engine. This means, it adjusts (advances) your timing during those periods where your engine has a high intake vacuum. The logic to tuning a vacuum advance is identical to mechanical advance, i.e., you want the maximum amount of advance without pinging. If you have dialed in your mechanical advance, then suddenly hear pinging once your vacuum advance is hooked up, then you want to reduce the vacuum advance settings. Usually, vacuum advance is adjusted via an Allen wrench through the vacuum canister vacuum port, or possibly inside the distributor. A lot of people, including myself, don't believe that the clutter of the vacuum canister and hosing is worth the minor driveability gains on a performance vehicle, and so choose to remove the vacuum advance. Of course, if you are going for a factory look, then you will want to retain it.
On the topic of bad gas mileage and rough running at low rpms, I suspect a vacuum leak. Do you smell a real noxious smell at idle and when cruising around? If so, I am almost certain you have a vacuum leak. Make sure that all of your intake manifold bolts are tightened down. Make sure that your carb bolts are properly snugged down (don't overtighten!). Make sure that all vacuum fittings are tight, all hoses and caps are pliable and snug, and all of your intake and carb gaskets are fresh and properly installed.
Best of luck!
« Last Edit: April 20, 2007 - 10:43:35 AM by Autophile »
1971 Cuda, black/black, 419 cu. in. 3G Hemi with twin turbos (build in progress), AlterKtion, Wilwood 12.19" disks, billet Rallye wheels
Offline Grec
« Reply #5 on: April 20, 2007 - 11:07:53 AM »
That's very helpful.
Many thanks!
- 440 Six Pack
