That purple AAR in that particular picture has almost stock suspension in it at that time...since I own it I should know. It has progressed into something more since that photo.
In stock form with the correct service replacement parts any mopar with f/r sway bars will handle surprisingly well. We set up a stock superbird to run Watkins Glen and it did well for its SIZE
If you do what I have listed below you will have quite the hot rod.
Now go get whatever you think is fast and get ready for your beating
Here is how it is configured now with the cost.
Quad Level One AAR ‘Cuda $3044 less tires/wheels
Tubular uca Urethane bushing RMS Chassis Components 250
Tubular adj strut rods w/rod ends RMS Chassis Components 199
Box lower control arms 50
Shocks QA1 adjustable… QA1 580
Springs Stock AAR 0.00
Urethane Spring bushings 40
Torsion Bars 1.040 Mopar 150
Sway Bars 1-1/8 front ¾ rear Firm Feel 500
adj front spring hanger [lowers car] 100
11/16 Seamless Tubing Tie Rod sleeves Firm Feel 175
20:1 Manual Steering mopar 375
Brake upgrade: wildwood dynalyte calipers
12 inch stock rotors, spindles 625
Total less wheels and tires $3044
16x8 Alum wheels with 255-50-ZR16 tires 1500
