Author Topic: Green wire from starter relay  (Read 1194 times)
Offline Winston
« on: April 22, 2007 - 07:42:33 PM »
I ordered the 4-speed safety harness....where does it go from the starter relay?  It has a grommet which makes me believe it goes through the firewall.  Does it go on something on the pedal?  The one end has the plug for the relay, but there was bare wire on the other end.  Is this harness some kind of ground?
Also, does anyone have a picture of how the 4-speed back-up light harness is chaneled under the car on its way to the plug on the tranny?  If not, can someone tell me the route for this harness?  Thanks so much!
Re: Green wire from starter relay
« Reply #1 on: April 22, 2007 - 10:26:12 PM »
the Green wire grounds on the switch on the clutch pedal , if you do not have the switch you need to ground that wire somewhere , I do not know of a repro part for the switch , you can get them on Ebay for a lot of $$
 the back up harness goes across the firewall & drops down the right side & goes over top of the trans where the tailhousing bolts to the main housing
Offline Winston
« Reply #2 on: April 23, 2007 - 11:20:55 AM »
Thanks CP, your imformation helps a lot.  I will check to see if the switch is on the pedal.  Thanks again!
Offline PlumCrazy
« Reply #3 on: April 24, 2007 - 01:42:10 AM »
Offline Winston
« Reply #4 on: April 24, 2007 - 11:25:45 AM »
 :thumbsup:  Thanks!
Offline LAA66
« Reply #5 on: April 25, 2007 - 01:09:52 PM »
 Hey Plumcrazy where did you get that clutch petal switch?  :drool:
Offline PlumCrazy
« Reply #6 on: April 26, 2007 - 09:45:41 AM »
That is my original switch, I just reworked it.
Offline LAA66
« Reply #7 on: April 27, 2007 - 07:46:50 AM »
 Did you repair it internally? If so would you please share some info? I would like to reconnect mine for saftey sake.
Thanks
Offline PlumCrazy
« Reply #8 on: April 28, 2007 - 10:22:45 AM »
Thanks
Nothing was wrong with mine internally, so it was just a disassembly, clean and plate and reassembly. really not much to it internally.
Offline LAA66
« Reply #9 on: April 30, 2007 - 04:30:56 PM »
 Checked the petal switch this weekend and the male prong had broken loose from the green wire. Switch is fine internally. After 25 years without it, I'm now back in business.
 Thanks for the inspiration. :2thumbs:
