Did it shear down at the pump, right where the hex starts? Is it an HV pump with 20-50 in it? On every rebuild, that oil pump drive should be replaced with a performance one. They have a harder shaft, with a shallow taper where the hex starts, and the drive gear is pressed and then pinned in place, instead of just pressed. A MUST with HV oil pump, and to keep your timing under control. I see way too many rebuilds where teh bushing in the block is new, and the drive is the used part. My guess is, the repair will cost more than the $65 part would have. It's too bad, but at least you were still at home, not cruising the interstate.
