Author Topic: Seat Coverings. How Hard is it to Install??  (Read 2513 times)
Offline DAYLEY/CHALLENGER
« on: April 24, 2007 - 08:04:28 PM »
I am just about to order my seat upholstery.  Still deciding who to get it from.  (YO, Leg, or Pad).  Anyway, If you leave the new covers in the sun to warm them up, won't they be east to install?  Guess I am hoping for an easy button!!
Dave or David
Offline willhaven
Re: Seat Coverings. How Hard is it to Install??
« Reply #1 on: April 24, 2007 - 08:52:11 PM »
A hair dryer could be helpful too.
I read the Project Charger book and I believe he used a hair dryer to get the kinks out of his vinyl top before installation. I guess it just makes everything more workable and pliable.
I know it's not a seat, but if you'd rather work inside, the dryer might be the way to go.
Offline EvilTwinATX
« Reply #2 on: April 24, 2007 - 09:43:45 PM »
Check  out LAMOPAR.com.... http://www.lamopar.com/How%20To's.htm
Step by step install.... good luck. I will be doing the same thing shortly.
Offline 70challengerrt
« Reply #3 on: April 25, 2007 - 04:17:48 AM »
I usually recover about 3-4 sets of mopar seats a year. IMO use Legendary not PYU covers if possible. Legendary fit better and have all the little things right to make them look original. Not that PYU are bad they just don't fit quite as nice and they will have for example exposed zippers. I use a electric oven to heat the covers, Don't use gas. Set it at about 200-250 put them in for about 30 min. make sure the face of the covers are not on the grates and they are as far from the elements as possible. I have used the laying them in the sun method and i works good also but do it on a warm day and obviously it works better on dark covers. Go to a local hardware store/crafts store and buy hog rings and a hog ring pliers and your set. Just watch how you take them apart and do one at a time.
« Reply #4 on: April 25, 2007 - 06:54:35 AM »
David, this pic. is from Cody's page but shows the most difficult part to get right.(his is a '70 with open back mine a '73 but that area is the same)  See the wrinkles in the corners at the top of the insert, I probably spent more time there than anywhere & it turns out that most of that is taken out with tension at the very bottom, warm up the vinyl & keep pulling at the bottom before you put the hog rings in. I think some wrinkle there is par for the course tho. Also found a broom handle handy to slide into the tight spaces to help position the cover on the cushion.
Offline matt63
« Reply #5 on: April 25, 2007 - 09:29:50 AM »
The back seat is easy but the fronts are difficult.  If the foam is still good that will help.  A local shop quoted me $500 to install the front covers!
Matt in Edmonton
'68 Valiant
« Reply #6 on: April 25, 2007 - 11:34:44 AM »
I must be out of touch but who is PYU??....By the way, I got the best price from Dante's.  I would probably use the sun method.  The wife needs to not have to clean the stove!!
Dave or David
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #7 on: April 25, 2007 - 11:52:24 AM »
its  PIU.
« Reply #8 on: April 25, 2007 - 01:50:11 PM »
 :clueless:   Same Question.  Who is PIU? :dunno: :dunno:
Dave or David
Offline 70_challenger
  • Suburban Detroit, Michigan
« Reply #9 on: April 25, 2007 - 03:38:38 PM »
David:
I can only speak from my experience.  The covers for my car (1970 black vinyl, with NOS cloth inserts) came from Legendary, and they are beautiful.  I am having a friend install them, and they fit really well (after repairing a bit of the old foams).  As you correctly stated, it helps a bunch to heat them in the sun.
I ordered mine at the Nationals in Columbus, and they had a 'show special' price.  They were still VERY expensive, but look awesome.
I hope the picture below helps you out - Give it a try!  Good luck.
Tom
« Last Edit: April 25, 2007 - 03:41:14 PM by 70_challenger »
« Reply #10 on: April 25, 2007 - 08:37:25 PM »
Thanks Wade for the pic and Tom, thats the button I needed.  I do believe that I will try to do it myself.  If they don't fit right, just take them off and try again.  There are a lot of things I have learned on this site that I didn't think I had the nerve to take on.  Proved myself wrong.  A person has to try or they don't succeed at anything.  But the question remains....who is PIU?
Dave or David
Offline EvilTwinATX
« Reply #11 on: April 25, 2007 - 08:48:44 PM »
Its PUI ... LOL
http://www.pui.cc
Their parts are pretty good... they are a supplier for YO and others.
« Reply #12 on: April 25, 2007 - 08:56:47 PM »
Parts Unlimited Interiors....PUI.  just found that on another thread conversation............They sell for  $219 for front buckets.!!!
Dave or David
Offline ted
« Reply #13 on: April 25, 2007 - 09:39:37 PM »
and they are not as good as legendary.
Offline IMNCARN82
  • LeDZeP
« Reply #14 on: April 27, 2007 - 06:32:42 AM »
I want to install some covers too...    :popcorn:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
