Since you can at least start the engine, you should be close.
I'd start with around 12-14* BTDC and see how happy it sounds from there. Just remember, if you advance too much you get ping.
Are you using a vacuum advance, or not? That comes into play here too, as you will need to retard the initial advance some if you are useing a vacuum advance.
