Author Topic: Differences between a 440-4 and 440-6 parts wise.  (Read 895 times)
Offline willhaven
« on: April 27, 2007 - 08:15:06 PM »
Aside from the carb setup, what is different between a 4 barrel and 6 barrel car? If I wanted to go from a 4 barrel to a 6 barrel car, what would it cost (with new non-original reproduction parts)?
How much performance do you really gain from a 6 pack setup?
Offline AMXguy
Re: Differences between a 440-4 and 440-6 parts wise.
« Reply #1 on: April 27, 2007 - 08:22:20 PM »
The rods, cam and pistons ( compression ) are about it. I rebuilt my 440 with the heavy rods and everything to six pack specs incase I wanted to add it but on the dyno with an 800 CFM carb it's making six pack power. if I add the six pack it will be mostly for looks.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #2 on: April 28, 2007 - 02:08:52 AM »
the balancer & flywheel is also different with the Hp [6pack] engines
 you do not need all the HP parts to use a 6 pack , generally the advantage with the 6 pack is the carb is finally bug enough to feed a 400 wide open  & the cruising economy tends to be good using only the 2bbl most of the time
generally a single 4bbl in the 850 or bigger range with a good intake will match the 6 pack for HP
