Author Topic: Gas Fumes  (Read 1002 times)
Offline VTMopar
Gas Fumes
« on: April 28, 2007 - 07:40:07 AM »
Got my Challenger back yesterday from a winter-long "spruce up" and although there are no leaks on the garage floor, the gasoline fumes are quite strong.   They removed the tank and reinstalled the sending unit -- engine was pulled, carb kit,  etc.   Anybody got any ideas what could be causing these fumes?     :feedback:
VT MOPAR
VT MOPAR
Re: Gas Fumes
« Reply #1 on: April 28, 2007 - 05:01:47 PM »
look for signs of fuel on the intake manifold especially near the carb fuel line connection.
Re: Gas Fumes
« Reply #2 on: April 29, 2007 - 04:25:53 AM »
  :iagree:  :iagree:  :iagree:
This will pop up when you get the car running.
Also, do you have a full tank of gas? I'm just wondering about a leak around the sending unit, or filler tube. If your tank isn't full, maybe just the vapors are getting out for now.  :dunno:
Offline VTMopar
Re: Gas Fumes
« Reply #3 on: April 29, 2007 - 08:32:27 AM »
Mike:   I think that is it...... I filled it up on the way home!
Thanks for the advice.
Vermont MOPAR
VT MOPAR
Offline Stacked440
Re: Gas Fumes
« Reply #4 on: April 29, 2007 - 09:22:01 AM »
If that doesn't work, id check your fuel vent line hoses.  If theres something wrong with the hose it vents a lot of fumes, more than you'd think :smilielol:
-Kyle-
Offline VTMopar
Re: Gas Fumes
« Reply #5 on: May 01, 2007 - 08:00:26 PM »
Hi    Mystery solved - found a pin-hole leak next to vent....... problem solved!   :jumping:
Thanks for the help!
Vermont MOPAR
VT MOPAR
