Author Topic: 383 engine assembly help  (Read 1031 times)
Offline moparnut
    • My Photo's
« on: April 28, 2007 - 10:10:51 PM »
OK i have a new 383 i need to assemble,I want to try and do it myself but its been 20 years since i have put an engine together so i dont know where to start.Any books or websites to help me?A buddy said his new engine failed because his assembler didnt break in the cam.Do you break in a cam at assembly?I thought it got broke in when you break in the motor???
thanks for any help
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline FY1Cuda
Re: 383 engine assembly help
« Reply #1 on: April 28, 2007 - 10:53:24 PM »
We found "How to Rebuild Big-Block Mopar Engines" very helpful.  It goes through a 383 and has lots of pictures.  It is available through Amazon--search "big-block mopar engines."
Offline moparnut
    • My Photo's
« Reply #2 on: April 28, 2007 - 11:12:02 PM »
I'll try that,in fact i may already have it,have to dig for it though,thanks
« Reply #3 on: April 29, 2007 - 11:47:21 AM »
the cam needs to be properly coated with special lube when installed but is broken in during the first few minutes of run time
Offline moparnut
    • My Photo's
« Reply #4 on: April 30, 2007 - 07:18:17 AM »
thanks Chryco,thats what i thought,my buddies off as usual
Offline 73EStroker
« Reply #5 on: April 30, 2007 - 07:53:04 AM »
 :iagree:with CP. And get your engine up to at least 2000RPM for at least 15-20 minutes to fling lots of oil around,  float the valves somewhat and get the lobes run in properly. Myself - I will be running the Indy setup for initial start with the inner springs removed. We will use compressed air to replace the inner springs after the first start.
Barry (Salmon Arm)
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #6 on: April 30, 2007 - 06:49:40 PM »
I can't exactly help you moparnut, but I'm looking to start the exact same project, so maybe we can bounce some ideas back and forth down the road.
Have you started collecting your parts yet?  What are your plans?
Jeff
Offline moparnut
    • My Photo's
« Reply #7 on: April 30, 2007 - 09:20:50 PM »
The donor engine is done,(My numbers engine is Bagged)I had to sleeve one cylinder in the donor motor.Its 30 over,trw forged l2315's i think(Chryco's recommendation)Balanced,67 915HP heads(should give me 9.8 comp),Lunati Voodoo #60303LK
Advertised Duration  Duration @ .050 IN/EX(268/276 226/234)  Gross Valve lift IN/EX(.494/.513)LSA and ICL(110/106)  RPM Range(1800-6200) Behind a 4 speed for my Bee,no power anything,manual breaks,steering so i can have a nice thumper without having to worry about vacuum
Offline ViperMan
    • JS Custom Cars
« Reply #8 on: May 16, 2007 - 08:32:31 PM »
I just ordered this book on Amazon.  $15.90 for New from a third-party seller, shipped.  Not a bad investment if you ask me.
Jeff
