Author Topic: brake parts  (Read 1283 times)
sleepychallenger
brake parts
« on: April 29, 2007 - 07:27:38 AM »
i am putting disc brakes on my 70 challenger from a 73 satalite. are there some kind of springs on the caliper bolts that are suppoesed to be there?
Re: brake parts
« Reply #1 on: April 29, 2007 - 11:24:00 AM »
yes . on the pin type calipers there is a folded metal anti rattle clip under the bolt
sleepychallenger
Re: brake parts
« Reply #2 on: April 30, 2007 - 12:06:32 AM »
what do i  ask for to get a new one or does anyone have any extras?
Re: brake parts
« Reply #3 on: April 30, 2007 - 08:20:16 AM »
if you buy calipers semi loaded they come with all the sprongs & new pins etc , not sure if the hardware kits is available for them separatly but it should be
sleepychallenger
Re: brake parts
« Reply #4 on: April 30, 2007 - 12:34:46 PM »
i have new calipers and hardware kits coming in. hopefully i they will be in there.
sleepychallenger
Re: brake parts
« Reply #5 on: May 02, 2007 - 05:39:48 PM »
anyone have pictures? i will post what came in the kit in just a bit
Offline RUSTY Cuda
  • One big step foward!
Re: brake parts
« Reply #6 on: May 02, 2007 - 06:37:54 PM »
First pic is the ones that came with the new callipers, couldnot figgure out how to get em on so I used the old type I had ! (2nd pic) :clueless: Rich.
« Last Edit: May 02, 2007 - 06:44:55 PM by RUSTY Cuda »
sleepychallenger
Re: brake parts
« Reply #7 on: May 02, 2007 - 06:50:56 PM »
thanks, that is what my new ones look like but i cant figure out how that would work either. does anyone have any extra old style ones?
Offline RUSTY Cuda
Re: brake parts
« Reply #8 on: May 02, 2007 - 06:58:56 PM »
I got lucky a friend had 2 new ones & i actually had 2 left on the car, napa didn't have them, there is a chance that an older parts store might just have em hangin on a brake parts rack, I can't find my pic of the new ones still in the pac, was hopin to scope a part # for ya. Rich.
sleepychallenger
Re: brake parts
« Reply #9 on: May 02, 2007 - 07:12:09 PM »
i will figure it out, my fav part is that i will finally have disc brakes
Offline RUSTY Cuda
Re: brake parts
« Reply #10 on: May 02, 2007 - 07:14:45 PM »
I don't think you really need em ,on my 74 they are missing, brakes work fine, haven't driven it enough to know if they actually rattle or not? Rich.
sleepychallenger
Re: brake parts
« Reply #11 on: May 02, 2007 - 07:33:00 PM »
as long as i stop and the brakes dont fall off, im good
sleepychallenger
Re: brake parts
« Reply #12 on: May 27, 2007 - 02:27:46 PM »
well i went to do the swap today and found that i have to have the banjo style brake lines and that the arm that goes to the tie rod end would not work so i have to use the one from my drums. i hate it when this happens
