Wheel - wide - backspace..??
Author Topic: Wheel - wide - backspace..??  (Read 2098 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: April 29, 2007 - 10:40:48 AM »
How wide wheels, and wich backspace, will go on a Challenger, with NO relocations and nothing, just stock..???
nivvy
Re: Wheel - wide - backspace..??
« Reply #1 on: April 29, 2007 - 10:47:07 AM »
8 inch wide with  4 1/2 backspace...
« Reply #2 on: April 29, 2007 - 11:24:51 AM »
I use 8" with 4 " backspace for the best fit
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #3 on: April 29, 2007 - 11:27:01 AM »
Then we can sum up, there will be room for 8½" with 4½" backspace..???
nivvy
« Reply #4 on: April 29, 2007 - 11:38:40 AM »
I used to have 8.5 convo pros with 5 inch backspace and the tire just rested on the spring...but the tires were MT ET Streets 28*12.5*15's ... you should be ok!
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #5 on: April 29, 2007 - 11:44:14 AM »
OK then..
We can have 5" in, and 4" out.. Total of 9"..???
Any higher.. :cooldancing:
« Reply #6 on: April 29, 2007 - 12:06:23 PM »
Just to play it safe, I wouldn't go more than 4.5 inches in.
nivvy
« Reply #7 on: April 29, 2007 - 12:07:12 PM »
You should worry more about tread width of the tire.... no matter what rim width you use on a stock rear your probably only gonna get a 275/60/15 in there!!!
« Reply #8 on: April 29, 2007 - 12:10:09 PM »
That will work fine without any modifications.  :thumbsup:
« Reply #9 on: April 30, 2007 - 06:38:53 AM »
I know you can get a 10" wide wheel in there with up to 5" of back space, however, tire choice and section width of that tire becomes critical. I also know you can fit a 295/50 tire in there. Again, the section width is the sizing factor and wheel back space selection becomes critical. I don't know if you could fit a 295 on a 10" rim together in there. Logically it is possible, but it would probably require some odd back space dimension that is not offered off the shelf. A 9.5 width with up to 4.5 of back space would be no problem. You might be able to squeeze a 295 in there on that rim size. A 275 on an 8" rim fits without any trouble at all.
I have 295s on an 8" rim under my Challenger. They fit fine and look like an old trans am racer, but isn't the best combo of wheel and tire as I have to run the tires around 22-24 pounds of air to get full tread contact.
« Last Edit: May 01, 2007 - 04:40:57 AM by HP2 »
Offline ShelbyDogg
« Reply #10 on: April 30, 2007 - 08:28:05 PM »
I had a 15x8.5 centerline Auto/Drag witha 4-7/8" back spacing. Had a 275-60R-15 on it with no rubbing ar jacking up anything.
Offline ragtopdodge
« Reply #11 on: May 01, 2007 - 12:19:17 PM »
I had 16x9s on my Chally w/5" BS.  They're currently on my B'Cuda.
However, I can only fit a 245-50 as any wider will go into the fender lip (plenty of room to the spring for bigger tire).
If I rolled the fender, I'm sure I could have gotten a 275-50.
-r
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
