Author Topic: Are automatic and 4-speed Cuda consoles interchangeable?  (Read 1644 times)
Offline jeryst
« on: May 02, 2007 - 10:59:02 AM »
My 73 Cuda project is a 4-speed, and the console in in bad shape. Someone fairly close is advertising one from an automatic that is in excellant shape. Are they the same, or are there differences? I believe they look the same, but I don't know about internal brackets, etc. Also, can I just use my woodgrain insert since it is for a 4-speed?
Offline Mopar73340
Re: Are automatic and 4-speed Cuda consoles interchangeable?
« Reply #1 on: May 02, 2007 - 01:06:24 PM »
The console's are different between the 4-spd's and the auto's. There is a difference on the side next to the shifter boot. (see pics). The top plates will interchange as they are different around the shifter.
« Last Edit: May 02, 2007 - 01:08:44 PM by Mopar73340 »
Offline 70challengerrt
« Reply #2 on: May 02, 2007 - 01:48:06 PM »
Check out this link    http://www.cuda-challenger.com/cc/index.php?topic=30737.msg309253#msg309253
I cut my bottom plate and bought a new top plate and it works good. I know some other members cut theres also. I never heard of them having problems. If the auto console is cheap snap it up and all you will need is your top plate and probably new wood grain insert.
« Reply #3 on: May 02, 2007 - 02:00:23 PM »
Those are some great pics Mopar73340 posted.  :2thumbs:
My advice would be to modify your auto console if you think, you can. The 4-speed consoles go for big $$$.
Offline 71chmark
« Reply #4 on: May 02, 2007 - 02:07:04 PM »
Instead of buying a new top plate (over a hundred bucks) couldn't you just cut the auto top plate to fit and just buy the wood grain sticker/decal?
I may be schizophrenic,
« Reply #5 on: May 02, 2007 - 02:10:01 PM »
If you look at the screws on the side of the consoles in the above pics, the 4-speed cut-out is more forwardly placed, so I don't think that would work.  :dunno:
Offline 71chmark
« Reply #6 on: May 02, 2007 - 02:22:15 PM »
How about buy some aluminum stock, use the decal as a template and cut it or have it cut. That has to be cheaper than the $150 plus dollars the inserts are going for now.
« Reply #7 on: May 02, 2007 - 03:04:38 PM »
On the top plate there is a slight lip that would have to milled in. So it would be hard exspecialy if your making just one. IF you were making a bunch then it would be worth the setup time.
Offline Mopar73340
« Reply #8 on: May 03, 2007 - 01:57:51 PM »
Thanks Mike,  and I agree with the rest of your post.   :thumbsup:
