Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Pinion Angle
« previous
next »
Print
Pages: [
1
Author
Topic: Pinion Angle (Read 609 times)
nivvy
Guest
Pinion Angle
on:
May 03, 2007 - 11:00:11 AM »
This seems to be a big deal but how were the cars from the factory set??? I dont remember any of them having any shims on the springs... or do you only worry about pinion angle when modifying the car?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Pinion Angle
Reply #1 on:
May 03, 2007 - 02:27:38 PM »
the factory had to have some kind of jig to weld the seats onto the axle tubes at the right angle to match the springs used , so the only time you "should" have to worry about it is if you change the springs or diff housing
Logged
nivvy
Guest
Re: Pinion Angle
Reply #2 on:
May 03, 2007 - 02:30:48 PM »
Well I used a b body rear and superstock springs.... perches werent moved at at all....and added a 742 case to the housing
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Pinion Angle
Reply #3 on:
May 03, 2007 - 02:32:08 PM »
then I would check the pinion angle
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Pinion Angle
