Author Topic: 906 Heads CC's  (Read 755 times)
nivvy
906 Heads CC's
« on: May 03, 2007 - 01:37:06 PM »
How many CC's is the 906 head??? Im thinking 88
« Last Edit: May 03, 2007 - 02:31:52 PM by StrOkEr »
Re: 906 Heads CC's
« Reply #1 on: May 03, 2007 - 02:32:51 PM »
88-90cc , they are supposed to be 88 but do vary
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
Re: 906 Heads CC's
« Reply #2 on: May 16, 2007 - 08:25:54 PM »
Edelbrock has an aftermarket setup with 84cc's...  What's the advantage/disadvantage/idea to this?
Offline 6packCuda
Re: 906 Heads CC's
« Reply #3 on: May 16, 2007 - 08:32:01 PM »
84ccs will give you a little higher compression. The Indy 440EZ heads are available with 78cc chambers.
Re: 906 Heads CC's
« Reply #4 on: May 16, 2007 - 11:54:43 PM »
the reality is the Eddy head at 84 cc will raise static compression But the heat loss to alum is equal to 1 point of compression Loss so net gain is -.6 compression , to clarify you will lose approx 6/10 of a point of compression in effective cylinder heat so it will act as though you dropped not raised compression
Offline 6packCuda
Re: 906 Heads CC's
« Reply #5 on: May 17, 2007 - 08:51:20 AM »
I knew I shouldn't have posted an answer before Chryco. :banghead: I wish I had half his knowledge and experience.
