Author Topic: Tunes  (Read 2772 times)
Offline Rob72
Tunes
« on: May 03, 2007 - 08:19:01 PM »
I think this is a shot in the dark but I thought I would try.   :dunno:
My 72 Challenger has the original AM radio (still working), but when the car was painted a few years ago the antenna hole was filled in as it was corroded and a new one was never cut.  Is there any way to get my radio to work without cutting a hole in my car?  Wireless antenna or something like that?
Thanks for the help
Re: Tunes
« Reply #1 on: May 03, 2007 - 08:33:43 PM »
They exist...can't say how well they work
http://www.cal-mustang.com/showdetl-7-5686-23-0.html
Re: Tunes
« Reply #2 on: October 07, 2007 - 02:18:38 AM »
you could cut a hole in th e1/4 panel & use a T/A /AAR antenna , still have to cut a hole though
moparniac
Re: Tunes
« Reply #3 on: October 07, 2007 - 07:52:35 AM »
I have a 72 challenger and my hole was plugged... I have my small antenna hiding behind the fender going through the kick panel..back in the door jab area...those small plactic type antennas....
Offline miketyler
    • www.miketyler.net
Re: Tunes
« Reply #4 on: October 07, 2007 - 10:09:05 AM »
you mean like the short rubber whip antenna? I too need to come up with a solution on this as my fiberglass fender was replaced with metal and had no hole. I suppose an external aerial antenna would look more correct but I cant bring myself to cut the hole.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
nivvy
Re: Tunes
« Reply #5 on: October 07, 2007 - 10:19:29 AM »
 :2thumbs:
I'll run out and take a pic of mine!
nivvy
Re: Tunes
« Reply #6 on: October 07, 2007 - 10:29:26 AM »
 :2thumbs: there is a ridge in the fender so it stays back there real well......
Offline miketyler
    • www.miketyler.net
Re: Tunes
« Reply #7 on: October 07, 2007 - 10:32:58 AM »
Cool, thanks for that! Looks easy enough! I'll have to PU one of those soon.  :biggrin: :thumbsup: :biggrin:
72' Cuda restomod
70 Mustang Mach 1
