Author Topic: Headlights do not work  (Read 2095 times)
Offline gichy
« on: May 04, 2007 - 09:27:46 AM »
I am almost finished by car and I just tried to use my headlights and they do not work.
2 months ago I tested them and they worked with no issues, before I put the motor/trans in.
Now the rear lights/side lights and the fog lights work when I switch the headlights on.
I think there should be a loose wire some where, but where should I start looking.
Thanks Rich
1974 Barracuda, 340cid, 4 speed OD !!
nivvy
Re: Headlights do not work
« Reply #1 on: May 04, 2007 - 09:39:06 AM »
mymopar.com has wiring diagrams...
Offline GoodysGotaCuda
« Reply #2 on: May 04, 2007 - 09:41:26 AM »
Do you have a good battery to body ground? Messing with the engine, the battery may have been taken out, just checkin.  :bigsmile:
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #3 on: May 04, 2007 - 09:59:48 AM »
Are all the wire blocks on the firewall plugged in? Might have bumped a set of connectors putting the engine in and now have lost connection to the front light harness.
nivvy
« Reply #4 on: May 04, 2007 - 10:10:12 AM »
Offline gichy
« Reply #5 on: May 04, 2007 - 11:31:30 AM »
Thanks for the web site
Yes the battery is grounded to the body, I removed this ground and all of the lights went out then i put the ground back on and the headlights still do not work.
Thanks
« Reply #6 on: May 04, 2007 - 02:05:06 PM »
The only things I can think of, are the connector at the bulkhead for the harness is dirty. The other thing is possibly a bad headlight switch. I'm not familiar with Cuda's, so I don't know if the front road lamps are turned on when the switch is in the middle position, or all the way up. If it's the latter, then I might be on to something.
« Reply #7 on: May 04, 2007 - 02:11:58 PM »
Start at the lights themselves and follow the wires back. Maybe you mashed them with the engine and cut the harness.
« Reply #8 on: May 04, 2007 - 06:04:41 PM »
Shot in the dark ....so to speak.....maybe the floor dimmer is unplugged.
Offline Mt.St.BigBlock
« Reply #9 on: May 04, 2007 - 07:28:07 PM »
 :iagree: My brother had similar problem with his 72 Challenger...all lights would
work except headlights and it was a bad floor dimmer switch.
Hi Bullitt99...Nice pic of "the King" getting his DEA badge from Nixon in your sig!!  Jeff
71 cuda 383 3spd manual gy9
Offline gichy
« Reply #10 on: May 05, 2007 - 06:07:27 AM »
I have afeeling that it is the floor dimmer switch / high beam.
I have problems with this switch before
As soon as I get out of work I will check.
Thanks
Offline JayBee
« Reply #11 on: May 05, 2007 - 07:15:31 AM »
Thanks for the tip y'all. I haven't driven at night yet and because of this thread thought I'd check the headlights. Sure enough they didn't come on when I flicked the switch. After a few taps on the high beam switch they came on, must have done something while installing the new carpet.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline gichy
« Reply #12 on: May 10, 2007 - 06:36:24 AM »
Yea  :droolingbounce:
It was a loose wire on the high beam switch
Thanks guys
