Author Topic: Cometic Gaskets  (Read 1028 times)
nivvy
Cometic Gaskets
« on: May 04, 2007 - 10:19:36 PM »
Well do to Chyrco's Advice I am going with Cometic gaskets for My Indy MW 440 EZ Head Motor! $105.95 each  :faint: ahhhh what the heck....
Re: Cometic Gaskets
« Reply #1 on: May 04, 2007 - 11:30:02 PM »
well the alternative is chamgimg them approx once / year if you figure that is cheaper using regular gaskets
Offline KellysCuda aircard
  • Its good to be blown
Re: Cometic Gaskets
« Reply #2 on: May 04, 2007 - 11:46:01 PM »
Ran mine all last year, then reused them again this year after a rebuild and still seem OK. And thats with a huffer beating them up. :2thumbs:
Offline Projectmopar
  • Bandito Racing
    • Bandito Racing
Re: Cometic Gaskets
« Reply #3 on: May 08, 2007 - 10:23:16 AM »
Cometic gaskets are expensive but how valuable is your time? I run 13.2 compression on my 340 and Cometic gaskets have solved my problems with blown head gaskets. Like mentioned good for at least a race season or more.  :thumbsup:
Thank you for your time
Barry Conner
Offline matt63
Re: Cometic Gaskets
« Reply #4 on: May 08, 2007 - 10:41:53 AM »
Just make sure the surface finish on the heads and block is correct.  It is much smoother than the stock finish.
Matt in Edmonton
'68 Valiant
nivvy
Re: Cometic Gaskets
« Reply #5 on: May 08, 2007 - 12:15:37 PM »
mine would be used more for street....
Offline moper
Re: Cometic Gaskets
« Reply #6 on: May 11, 2007 - 09:20:53 AM »
yup...MUCH smoother
