Swapping gears on 8 3/4?
Author Topic: Swapping gears on 8 3/4?  (Read 3326 times)
Offline bb71challenger
« on: May 05, 2007 - 12:47:33 AM »
I just picked up a 741 case 8 3/4 open rear with 3.55's in it. I want to swap the ring and pinion over to one of my sure grip center sections. I have both types of sure grips, a 5.13 clutch type and a 2.94 and 3.23 cone type. Will there be a problem swapping the gears over to one of the other carriers? I prefer to swap over to the 5.13 clutch type as it is more easily rebuildable. Thanks for any help,
Brett
*Brett*
Offline Carlwalski
Re: Swapping gears on 8 3/4?
« Reply #1 on: May 05, 2007 - 01:56:38 AM »
It should be alright if the other diff is the same style case.
There were 3 styles: 741, 742 and 489. I don't think you can interchange.
So, just make sure the cases are the same. :cheers:
:2cents: :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline scf100
  • FAST LANE FOREVER!
« Reply #2 on: May 05, 2007 - 06:03:46 AM »
there is some info on this axle page that may help
http://www.mymopar.com/Mopar8_75RearEndGuide.htm
1970 Challenger R/T convertible 383…. 4-speed…3.91 suregrip
Triple Black
« Reply #3 on: May 05, 2007 - 09:04:45 AM »
Thanks for the infor guys. Looks like I dinged myself over by not making sure it was a 742 or 489 case. Anyone need a set of weak suck 3.55's?  :bigsmile:
*Brett*
« Reply #4 on: May 05, 2007 - 11:28:23 AM »
the sure grip will swap but the gears have to remain in the 741 case as I am sure you now know
 unless you have some serious traction I bet you still cannot break the weak 741 carrier/gears
« Reply #5 on: May 05, 2007 - 11:44:03 AM »
so I could use them along with a sure grip rear for say a slightly built 440? I will build it to be a solid street cruiser with maybe 500-550 horse at the flywheel.
*Brett*
« Reply #6 on: May 05, 2007 - 11:47:23 AM »
as long as the tires will spin I highly doubt you can hurt the gears
« Reply #7 on: May 05, 2007 - 11:55:49 AM »
Once again, thanks for the quick reply! Masta, masta, grassahoppa betty betty fankful  :bigsmile:
*Brett*
Offline Carlwalski
« Reply #8 on: May 05, 2007 - 08:09:03 PM »
What transmission are you running? Auto or Manual?
If it's a manual you may run a greater risk of blowing something.
« Reply #9 on: May 05, 2007 - 09:37:51 PM »
727. I most likely will not even have a stall convertor so I am hoping it will be fine. I think 3.55 would be perfect for me. If my engine is strong enough I would like to even consider keeping the 2.94 sure grip that is in the car now. I like the nice low rpm cruising speed.
*Brett*
Offline abodyjoe
  • Get It On....
    • A-Body Joe's
« Reply #10 on: May 17, 2007 - 06:14:22 AM »
i would leave the 3:55 ring and pinion in the case that its all ready set up in and just stick the sure grip unit from one of your other center sections in it...
  the sure grip units interchange between the different center sections...   most you'll have to do is change the bearings on it i believe...
Offline abodyjoe
  • Get It On....
    • A-Body Joe's
« Reply #11 on: May 17, 2007 - 06:17:10 AM »
  i don't think i would worry about the 741 case too much...  especially with an automatic....    i'm running a 741 in my dart and last time out had about 6" of air under the left front tire and it is still going strong....
« Reply #12 on: May 17, 2007 - 03:10:08 PM »
That makes me breathe a little easier. I did not want to spend 60 bucks on a pig I could not use.
*Brett*
Offline oldkimmer
« Reply #13 on: May 26, 2007 - 03:09:29 AM »
Considering all the max wedges and earlie hemies used the 741s I dont think u will have a problem...Ive seen a couple A bodies running 10s on a 741 case..............kim..........
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Offline 422STROKER
  • Member Since 6/3/06
« Reply #14 on: May 26, 2007 - 09:05:07 AM »
60 bucks was a good deal.
Tom
Tom
