Author Topic: Swapping gears on 8 3/4?  (Read 3327 times)
Offline moper
Re: Swapping gears on 8 3/4?
« Reply #15 on: May 29, 2007 - 07:33:34 AM »
  i don't think i would worry about the 741 case too much...  especially with an automatic....    i'm running a 741 in my dart and last time out had about 6" of air under the left front tire and it is still going strong....
And I got the picture to prove it...lol. I dont think you'll break it. I agree, leave the pinion in the case it started in, and swap the ring gear onto the sure grip, then install that in that case. Very easy...
Offline bb71challenger
« Reply #16 on: May 29, 2007 - 02:07:02 PM »
So a 489 case sure grip will work ok? I would like the use the clutch type I have so I can freshen it up easily. Does it matter that the sure grip I want to use is in a case with 5.13 gears? I have a few cone type sure grips as well if I need to use one of those. Thanks again for all the replies.
Brett
*Brett*
« Reply #17 on: May 30, 2007 - 12:37:28 AM »
either sure grip will bolt into any carrier
Offline oldkimmer
« Reply #18 on: June 03, 2007 - 12:26:38 PM »
 :canada:Even the mighty max wedge and hemi cars used the 741s as that was all the had available at the time......kim.....
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
