Author Topic: Need pic of 340 timing cover markings  (Read 1358 times)
Offline Katfish
  • 70 Challenger
« on: May 06, 2007 - 06:11:41 AM »
Does anyone have a close-up pic of the timing mark area for a small-block?  I can't tell if what i'm seeing is correct.  The pic shows what I think is there.  I'd like to verify so I can get my timing adjusted.
Thx
Offline 422STROKER
  • Member Since 6/3/06
Re: Need pic of 340 timing cover markings
« Reply #1 on: May 06, 2007 - 09:02:08 AM »
What kind of timing light do you have?  If you pick up a dial back type you can adjust it easily.
BTW ?I believe from what we can see it is 5?(On the top)
Tom
Tom
Offline Katfish
  • 70 Challenger
« Reply #2 on: May 06, 2007 - 10:19:43 AM »
I have a old Craftsman timing light.  I'm hoping someone has a clear pic of the area.  I believe the top mark is 5, but I'm not sure.
What doesn't make sense to me is why it has 10 AFTER and only 5 BTDC markings?  I keep reading we should be setting these motors to 10-15 BTDC?  If thats the case, it would not be possible to do back when these cars were new from the factory?
« Reply #3 on: May 06, 2007 - 10:22:20 AM »
I'm no help here, but on my 440, the last line you see is 10* BTDC. And yes, my timing is set a little beyond that.
« Reply #4 on: May 06, 2007 - 10:26:39 AM »
From my '73 340
Offline 422STROKER
« Reply #5 on: May 06, 2007 - 11:08:31 AM »
I think if you look up in there it will go to 10BTDC.  I bought a craftsman dial back for 50 bucks.  If you have some timing tape you could use that as well.
Tom :cheers:
If you're going to try and performance tune you should get a dial back light to check the advance at 3-3500 rpm.  Or less(rpm) depending on your engine.
Tom
Offline Katfish
  • 70 Challenger
« Reply #6 on: May 06, 2007 - 11:25:18 AM »
Thanks for all the replies, and the pic Bullitt!  The 10 BTDC marking is further up, as mentioned.  There was so much paint and grime I couldn't see it.  Once I poked it with a srewdriver all the paint flaked off.
It will be interesting to see if I can can notice a difference.  It was set to 0 exactly, I think I'll try 10 before as a starting point.
« Last Edit: May 06, 2007 - 12:42:24 PM by Katfish »
Offline IMNCARN82
  • LeDZeP
« Reply #7 on: May 07, 2007 - 07:06:07 AM »
scuff the lines with sandpaper to make them visible..then mark them. :dunno:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
