With the gearing and stick, I would go with the XE274HL. But, be prepared to do a little extra on the cam break in. It will need to be broken in with the inner springs removed, then they get installed. And, the heads will need the spring seats cut down and the guides arrorwed if they weren't for double springs. That low compression will hurt going much bigger, and that's a lot of gear for something smaller.
