Author Topic: Oil Changes  (Read 2029 times)
nivvy
Oil Changes
« on: May 08, 2007 - 02:09:51 PM »
Whenever you put in new oil in your car how long is it till it starts turning black in color ??? mine seems to change blackish after a few miles or so ???
Re: Oil Changes
« Reply #1 on: May 08, 2007 - 02:20:27 PM »
You just had that engine rebuilt, am I right? I only change mine once a year(1000-2000 miles), but it looks pretty good up until the last few months.
Offline pink panther
Re: Oil Changes
« Reply #2 on: May 08, 2007 - 02:48:44 PM »
 :iagree: mine looks pretty good after once a year
nivvy
Re: Oil Changes
« Reply #3 on: May 08, 2007 - 03:26:57 PM »
yes it is a new motor.... ???
Offline quagmire
  • Traction Impaired......
Re: Oil Changes
« Reply #4 on: May 08, 2007 - 03:48:59 PM »
What kind of oil do you use?  In reality, it's not a bad thing if it turns blackish.  That means the detergents in the oil are doing their job keeping the motor clean.  If it is freshly rebuilt, you don't have to worry about breaking any sludge loose and creating problems.  Do you run a PCV valve?  If you don't, if it is clogged, or the car is running very rich, it may be getting contaminated prematurely.
Re: Oil Changes
« Reply #5 on: May 08, 2007 - 04:27:19 PM »
I agree with the above, but also this could be a problem of your oil getting too hot. A friend of mine told me an oil cooler solved his problem. Just throwing that out there.
Offline matt63
Re: Oil Changes
« Reply #6 on: May 08, 2007 - 04:39:16 PM »
That doesn't sound right.  Is there an additive in the oil?  You can get the oil analyzed fairly inexpensively if you are concerned.
Matt in Edmonton
'68 Valiant
nivvy
Re: Oil Changes
« Reply #7 on: May 08, 2007 - 06:22:06 PM »
It is Castrol GTX 5w 30 ... yes there is a pcv built into the breather...
Offline LAA66
Re: Oil Changes
« Reply #8 on: May 08, 2007 - 06:58:19 PM »
 I run Castrol GTX also, 10w-40 proof. It is clean after a year with 500 miles, but I change it anyways.
 The PCV valve at the driver side valve cover is connected directly to Manifold vacuum on the base of a Holley 650. Also an air filter to valve cover breather on the passenger side. I think this is a correct set up but, I've been wrong before.   :popcorn:
Offline BIGSHCLUNK
Re: Oil Changes
« Reply #9 on: May 08, 2007 - 08:49:53 PM »
Looked at mine the other day (havent changed it...yet) still looks pretty good. Can't really say how many miles I put on last year tho..
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Volvolution
  • mmmm.... fried rice....
Re: Oil Changes
« Reply #10 on: May 08, 2007 - 08:59:32 PM »
And, If it is a new motor, thats pretty ok. Its probably still breaking in. They do that for a while sometimes. and some engines just run dirtier than others. So I wouldn't worry too much yet, depending on how new it is.
oh....... too many cars. not enuff money... not enough time....
{oo/======\oo}
kudakidd
Re: Oil Changes
« Reply #11 on: May 09, 2007 - 12:29:06 PM »
the color is a non issue, but I would use a higher viscosity oil.
Offline Mopar73340
Re: Oil Changes
« Reply #12 on: May 09, 2007 - 01:11:52 PM »
I run usually beetween 1K - 2K a year and the oil looks fairly clean when it comes out at the end of the year. Engine has about 6K on it.
Re: Oil Changes
« Reply #13 on: May 09, 2007 - 03:03:33 PM »
I would in no way put 5W-30 in my Chally. That's for the new cars. Way thin. 10W-30, or 10W-40 would do you better IMO.  :2cents:
Offline matt63
Re: Oil Changes
« Reply #14 on: May 09, 2007 - 03:26:18 PM »
Agreed but the oil only has 5W viscosity when it's very cold so it shouldn't really matter.  That said I use 10W30.
Matt in Edmonton
'68 Valiant
