Author Topic: AAR fiberglass bumper  (Read 3009 times)
Offline Travis72
Re: AAR fiberglass bumper
« Reply #15 on: May 20, 2007 - 08:59:39 PM »
There are no studs with the bumper.  You could drill through it and use bolts if you wanted to.  I decided to fiberglass in some studs to the back side of the bumper (see pictures).  I then made a real simple bracket out of aluminum (the red tape is just holding the two piece bracket in place, since I don't have the capability of welding aluminum).  I just used square aluminum tubing and flat stock.  You could also use steel.
FY1Cuda, yes I imagine you could fiberglass in a steel strip, or try the method proposed by 360Cuda.
Torred, did you get yours installed?  Just curious how you mounted yours.
Travis
72 Cuda
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #16 on: May 21, 2007 - 06:53:39 AM »
They come in black gelcoat.I want a smooth look so I am going to fab a piece of sheet metal and attach some studs to that and then fiberglass it to the inside just like Travis.I haven`t decided if I am going with the stock barckets or amking some lightwieght ones.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline FY1Cuda
« Reply #17 on: May 21, 2007 - 09:22:44 PM »
Thanks, Travis and Torred, for the info and pix. Looks very do-able. I'll probably put a steel strip all the way along it with studs welded into the strip and then 'glass over that. The price is certainly right for the project.
One last question: It's my understanding that the valences and elastomeric bumpers are different between '70 and the other years.  If so, is this a '70 shape bumper, or do they have a couple of different versions?
« Last Edit: May 21, 2007 - 09:53:04 PM by FY1Cuda »
Offline Travis72
« Reply #18 on: May 21, 2007 - 11:21:11 PM »
I think it's considered a 70????  If I remember right, I heard the differences was in the size of the cut out for the front license plate?  But to be honest, I don't know if that's true.  See if this picture helps?   :clueless:
Travis
72 Cuda
Offline IMNCARN82
  • LeDZeP
« Reply #19 on: May 23, 2007 - 02:16:04 PM »
 :woohoo:    looks very nice!  What does it cost?
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
