Author Topic: Groaning/creaking noise  (Read 1105 times)
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« on: May 12, 2007 - 11:23:32 AM »
When I start moving from a stop (easing the clutch out) there's a "groaning-creaking" hard to describe noise from the rear of the car.
Has urethane bushings on the rear bar...thought about those..
tried it with door open...same...?
Any thoughts on what to check?
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline 4Cruizn
  • HEMI FISH
Re: Groaning/creaking noise
« Reply #1 on: May 12, 2007 - 02:54:19 PM »
suspension / leaf spring bushings, probably dry
« Reply #2 on: May 12, 2007 - 04:56:07 PM »
Makes me think of drum brakes that need some attention, maybe a little grease on the rub zones.
  • HvacMan
« Reply #3 on: May 25, 2007 - 10:42:41 PM »
How are they lubed and what with?
Eric
Bay Area California
  • HvacMan
« Reply #4 on: May 25, 2007 - 10:44:00 PM »
Rub zones? Like various pivot points etc.?
Thanks in advance guys !
Eric
Bay Area California
« Reply #5 on: May 26, 2007 - 12:06:27 AM »
when assembling the rear shackles I use anti seize or wheel brg grease , same with the front bushing , I always use anti seize in there so there is a chance the front spring eye bolt can be removed int he future
 where the brake shoes rub against the backing plate & pivot pin thereis a special silicone grease to use there
« Reply #6 on: May 26, 2007 - 04:52:53 AM »
And yer sure it's not an axle bearing or u joint?
  • HvacMan
« Reply #7 on: June 01, 2007 - 11:27:49 PM »
not sure. it's hard to tell while i'm driving it. I'll have to try a couple of different things out.
Thanks again.
Eric
Bay Area California
