Author Topic: Freeze plugs..???  (Read 2009 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
Freeze plugs..???
« on: May 12, 2007 - 03:40:49 PM »
Will a smallblock have freeze plugs on the back side, - inside the converterhousing..???
Offline chrisII
Re: Freeze plugs..???
« Reply #1 on: May 12, 2007 - 04:05:28 PM »
sorry to say, if i remember correctly there are 2 freeze plugs along with the oil plugs and rear cam bearing cap. and there are pretty much only 2 ways to get to em, pull the motor, or drop the trans
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #2 on: May 12, 2007 - 04:12:24 PM »
 :bricks1:  :bricks1:  :bricks1:  :working:
« Reply #3 on: May 12, 2007 - 11:50:28 PM »
I do not remember a freeze plug inside the belhousing in the rear of the block , you do have them on the rear of the heads though
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #4 on: May 13, 2007 - 12:09:45 AM »
Yeps, those in the heads is OK,  - but I got a little water coming on the garage-floor from somewhere in the back of the engine..???
Offline chrisII
« Reply #5 on: May 13, 2007 - 02:04:15 AM »
I wouls go out n look at one but its 3:30 am an i just got in from a show, wearing my best pr of pants. so itll have to wait till im in work clothes.   ill try to look when i get up
« Reply #6 on: May 13, 2007 - 08:44:37 AM »
could be leaking at the rear exhaust studs or the back corners of the intake manifold
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #7 on: May 13, 2007 - 10:23:10 AM »
OK..
""back corners of the intake manifold""  Please explain a little more..
I have seen water dripping from the rigth headders, but it aint from the exhaust studs, and if it is from inside the converterhouse, how will it get to the headders..???
So this manifold thing sounds likely..
« Reply #8 on: May 13, 2007 - 10:53:08 AM »
there is water ports at the rear of the heads , there are blocked by the intake but can leak & run down the rear fo the engine , you need to pull the intake & replace the gaskets to fix it
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #9 on: May 13, 2007 - 02:12:22 PM »
I'll check that out, - thank you...
nivvy
« Reply #10 on: May 13, 2007 - 02:45:47 PM »
Freeze Plugs totally suck! I had a bad problem with them because I was to stupid to put antifreeze in the car over winter! I had the block pulled and replaced them all..... I guess Im lucky the block didnt crack!
 :burnout:
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #11 on: May 13, 2007 - 03:18:23 PM »
I just took a better look... :clueless:
Water all over the engine, front crossmember, pan, and so on... :bricks1:
Dont see any bad freeze plugs dow..
nivvy
« Reply #12 on: May 13, 2007 - 03:39:30 PM »
I had the freeze plugs from behind my headers leaking down and behind the motor mount which is very hard to see....
Offline tactransman
« Reply #13 on: May 13, 2007 - 05:33:00 PM »
There are two 1 5/8 inch freeze plugs on the back of the block,I keep them in stock at the shop because it seems like they are the number ones to go bad because of lack of circulation. Best time to change them is when the tranny is out. :grinyes:
Terry-tactransman
Union, Mo.
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #14 on: May 13, 2007 - 06:19:00 PM »
There are two at the back of the block.
